Help Having Problem with startup
Old Dec 6, 2016 | 06:32 PM
MrEvo9Mong's Avatar
Been having this problem for over a good month or so after car was shipped from VA to CA. Only happens when the car sits for a good 4+ hrs and on cold start in the morning. Already had the COP rebuilt by Matt from SpoolinUp, replaced ETS Mini Barrery, and spark plugs. Fuel pumps and injectors are all in good working order and been on E85 for 6 months now. (sometimes) During high RPM WOT the car will throw a flashing CEL idk what it is but that got me curious
any idea? Im thinking its for the crank sensor? Cause sometime my CEL will come on for a code P0335 and the code will clear a few days later and i did a WOT pull with that CEL out of curiosity it started flashing on and off, sooooo please any input will help im stuck in a hole now thanks! (Attachted is a video for my startup in the morning)
Mods:
GSC S1 Cams
GSC Springs/Retainers
DW300 Fuel Pump
1050 FIC Fuel Injectors
Synapse DV BOV
Muse IC Piping
ETS 3.5inch FM Intercooler
ETS Intake
Invidia 76mm Test Pipe
MAP Dump/Down Pipe Combo
Tomei Titanium Exhaust
Mishimoto Radiator & Hoses
Spoolin COP Kit
VIDEO:
Old Dec 6, 2016 | 08:47 PM
barneyb's Avatar
Not factory but a common feature added to the ECU is flash on knock. Knock, if it going to occur, will occur during WOT.
Old Dec 6, 2016 | 09:05 PM
MrEvo9Mong's Avatar
So is it a warning? Or a sign my **** is now a ticking time bomb?
Old Dec 6, 2016 | 10:26 PM
barneyb's Avatar
Its a warning. Better that you didn't see it flash. Too much knock can damage the engine. As for the hard start, the code is probably telling you it is time for a sensor change. One of these days it may leave you stranded.
Old Dec 7, 2016 | 05:05 AM
MrEvo9Mong's Avatar
ill have the sensor change than, guess ill have to rebuild my block to rid of the knock? Or is there something else i can do
Old Dec 7, 2016 | 12:57 PM
barneyb's Avatar
I'm no tuner but cars always knock. The ECU keeps a running tab of knock and if the number gets too big the computer has been programmed to flash the check engine light.
Various things you can do to reduce knock include: higher octane gas, less spark advance or less boost. You'll find threads on here where people are chasing the cause of knock.
Anyway, since your CEL flashes it has a tune of some sort. Maybe visit a tuner.
Old Dec 7, 2016 | 01:35 PM
MrEvo9Mong's Avatar
Yes the car is tuned on E85, but thanks for the help I'll probably take it to a tuner and have him check it for the CEL flashes. But still to figure that hard start out.
Old Dec 7, 2016 | 02:15 PM
Bhsj13's Avatar
There isn't a local tuner here in Norfolk area.you could go to Moore automotive in Fairfax or force fed in NC, which you may know already. However, Chris Carbee will be at All Aspects Motorsports tomorrow for tuning if you know who he is. You should head there and see if he has a spot for time to look at your tune. Good luck!
Old Dec 7, 2016 | 03:35 PM
MrEvo9Mong's Avatar
Im no longer in the Norfolk area i moved to Cali and my car was tuned by Devan from AWHP Tuning in richmond. He's really good but now that im no where near him ill have to find someone near my new area for tuning. All in all thanks!
Old Dec 7, 2016 | 06:43 PM
Bhsj13's Avatar
where are you at in Cali?
Old Dec 7, 2016 | 07:38 PM
MrEvo9Mong's Avatar
Unfortunately Sacramento theres not a single tuner shop or tuners i know that are base in here, closest evo tuners i found near me are Boosted Tuning in Chico 1hr 45min or so away from me.
Old Dec 8, 2016 | 04:39 AM
Bhsj13's Avatar
yeah you have that shop and FFTEC. it will be worth the almost 2 hr drive ,am.
Old Dec 8, 2016 | 09:05 AM
MrEvo9Mong's Avatar
Yea probably jus gonna wait until i can slap on a black, s2's, and couple more ported bolt on and ill go for a tune at Boosted. But is it safe to drive it daily under safe boost?
Old Dec 8, 2016 | 08:56 PM
MrEvo9Mong's Avatar
Still need help on hard start...
Mitsu_Evo_MR
Nov 5, 2008 06:43 PM
rcheung
Sep 11, 2008 10:17 AM
BoricuaEVOX
Jun 4, 2008 04:32 PM
mainframe23
Lancer Troubleshooting
Jan 2, 2007 08:28 AM
