Turbo swap
Turbo swap
So I'm looking into swapping out my 8 turbo for either a pt5858 or 6262. What exactly is needed to complete this job? I don't want to do a forward facing turbo since this is my current daily. I would like to be in the 400hp range on 91 pump gas, would go e85 if it was available in my area of Cali in case you were wondering haha.
Current mods:
Fic 1050's
Kelford 272's
Walboro 255
Ets licp
Short route uicp w/ synapse DV
built evo 8 head with super tech and gsc parts
AEM short ram air intake
Turbo back exhaust catless DP
Note:
I do still need to order and 02 housing and intercooler.
Any help with what parts are needed to do this job will be appreciated. Thanks
Current mods:
Fic 1050's
Kelford 272's
Walboro 255
Ets licp
Note:
You should probably look around a bit..Unless your bottom end is built, and the turbo and setup would be worth the cost, i would get a stock replacement. An FP green would get you over 400 pretty easily.
Of course I'm going to sound biased but a Green would work really well with that setup and see no reason why you couldn't easily squeeze 400WHP out of 91. If you have a 10.5 hotside on your stocker I can upgrade it for about $1200 or so with all the bells and whistles. Brand new I sell journal bearing Greens for $1695 and it doesn't require changing anything on your current setup.
But to answer your question about what it would take to swap to turbo like that.
Manifold
O2 housing
Oil line
Oil return - Flange may be the same but length and size may need to be changed.
Intake - May just need a coupler.
- Michael
Manifold
O2 housing
Oil line
- Michael
Manifold
O2 housing
Oil line
- Michael
Manifold
O2 housing
Oil line
- Michael
Why not just keep your stock turbo if it has a 10.5 hotside? Should be easy with those mods and Have tscomp tune it. E85 would help as well but you can prob make that on pump, but being our in cali you could do pump and meth.
Yeah if I don't go with an FP turbo ill be looking into a few standard location setups. I'll definitely have to look into those gtx turbos. N I'm located bout 45 mins south of San Jose.
I feel ya, I've read a lot of good reviews on them. N I started second guessing something as big as the 6262. I was watching YouTube videos with that turbo n got all antsy about wanting more power haha.
Well like I said I'm a noob with turbos still lol. So with having a 10.5 hotside what could be done to it? I mean I know it could be rebuilt, but what is done to it? And yeah e85 is outta the question. Neatest station is 50+ miles away I think. N as for a meth kit? What kit would you recommend?
Current mods:
Fic 1050's
Kelford 272's
Walboro 255
Ets licp
Note:
Current mods:
Fic 1050's
Kelford 272's
Walboro 255
Ets licp
Note:
