ACT's solution to the most common pull-type clutch issue..
Old May 6, 2013 | 06:25 PM
Anarchy99's Avatar
Originally Posted by ACTman
Did you see the video? It installs and disassembles just like the factory parts.
Yes, but didn't see you sticking a screwdriver and a flashlight into a 1" hole while pulling on a release fork, turning a screwdriver and swinging a hammer at the fork protrusion.
I guess only time will tell how this works in the real world Evo application as installed in a transmission case.
Old May 6, 2013 | 09:19 PM
Sir2egk's Avatar
Nice piece
Old May 6, 2013 | 09:53 PM
car_guy507's Avatar
so if a person gets monoloc does this mean that a clutch fork stop is now not needed?
Old May 7, 2013 | 11:13 AM
silverevo05's Avatar
What do you mean? Will it be difficult to take out? Per the video it's the same as stock to insert and remove
Old May 7, 2013 | 11:35 AM
ACTman's Avatar
IMO the fork stop will no longer be needed.
Old May 7, 2013 | 04:40 PM
juanmedina's Avatar
The answer is Yes! They are available on our website right now. You can type in Monoloc in the search field and it will take you right to it. Distributors have already started ordering them so they will have them in stock real soon. For recent ACT customers, we are offering an upgrade discount.
How recent? I bought and ACT clutch for my STi about 6 months ago and actually today after a miss shift the clutch went all the way down to the floor . I pull back on the clutch fork and it doesn't want to engage the pressure plate. I imagine the throw out bearing is done. The funny thing is that I purchased a PTE 6466 from Nate at MAP last week. Too much power bro.
I have the xtreme pressure plate with a full face disk and this asap.
Old May 7, 2013 | 09:57 PM
ACTman's Avatar
6 months is no problem. You can contact us directly at sales@advancedclutch.com for more details.
Old May 8, 2013 | 04:14 AM
juanmedina's Avatar
thanks and I sent you a PM
Old May 9, 2013 | 04:25 PM
juanmedina's Avatar
The monoloc will make this issue a thing of the past
Old May 9, 2013 | 05:41 PM
TommiM's Avatar
placed by order today through MAP
Perfect timing from ACT, I just happen to be putting my new clutch in.
Old May 9, 2013 | 07:10 PM
Dynotech Tuning's Avatar
This product guarantees that the TOB separation won't happen or just much less likely? It would appear to be susceptible to this same issue unless I missed a key feature. I assume the issue was more about the ring sliding up/down the fingers and this product is one piece so the "ring" is always in a guaranteed position.
-Jamie
Old May 9, 2013 | 08:02 PM
batty200's Avatar
The ring can't become dislodged and that is what causes the failures. Since the ring is cast in place you know it isn't moving.
Old Oct 10, 2013 | 02:35 PM
I just ordered mine today...Hopefully Mitsu wont give me a hard time with installing it
Old Oct 10, 2013 | 10:10 PM
barneyb's Avatar
I had a monoloc in a new clutch on the work bench and I was playing with it, snapping the throwout bearing in and out and all of a sudden it wouldn't release. I finally got it apart after considerable work. Now its in my car and I figure the connection is permanent.
Old Oct 14, 2013 | 09:33 AM
^ do you think it will be hard to take out when the time comes?
