Manley piston ring gap
Old May 13, 2013 | 09:14 PM
06mr775's Avatar
I was wondering if anybody had any experience with Manley pistons and their ring gap formula. Im building a 4g64 with turbo tuff long rods and the manley pistons to match. According to their formula I would be running somewhere around .018" on the top ring and .011" on the second. Does that seem a bit to tight?? Im going to be running a 35R and plan to upgrade to a HTA86 in the near future. Input would be greatly appreciated.
Old May 14, 2013 | 05:28 AM
evolve_VIII's Avatar
Thats way too tight. On my 4g64 build I went .022" on the top and .026" on the second ring.
My piston to wall is .00425"
Old May 14, 2013 | 09:42 AM
tkklemann's Avatar
Crazy, I built my 4G64 to those EXACT same numbers....
Old May 14, 2013 | 10:05 AM
06mr775's Avatar
Thats about the specs I thought were right... how much power are you making on this set up and what turbo?
Old May 14, 2013 | 10:52 AM
Well Im going to fire it up this weekend. Once broken in and dyno'd, I should be making around 600hp on e85 running an FP black.
Old May 14, 2013 | 11:25 AM
06mr775's Avatar
Very nice, did you have to notch the block at all for the connecting rods to clear?
Old May 14, 2013 | 12:05 PM
I did not have to notch the block. I did add the oil squirters and had to tweak them to clear the pistons.
Old May 14, 2013 | 08:04 PM
ExViTermini's Avatar
What rods are you using evolve?
Old May 14, 2013 | 08:47 PM
06mr775's Avatar
Im curious as well...the only ones I've ever seen clear are the 156mm manley H-beams...
Old May 15, 2013 | 07:41 AM
Im using the manley H-beams. Wiseco 1400 pistons. 9.0 to 1. 2.4L nitrited crank and 150mm rods.
Old May 15, 2013 | 08:09 AM
Ahh, yea the I beans are the ones that dont clear. I notched the casting at number 3 and bottoms of all cylinder walls though I don't think that was necessary looking at it after assembly.
2006GSR
10
Jun 17, 2019 11:07 AM
cerevo
12
Sep 9, 2016 03:45 AM
ezzey
Dec 6, 2012 09:58 PM
evoyrrah
29
May 8, 2012 12:20 AM
MechanicDave
Mar 2, 2011 06:52 PM
