Transmission help!
Old May 16, 2013 | 03:18 AM
DYTNEvo's Avatar
Transmission help!
Hey Guys Just got my tranny back today and I am having the absolute hardest time ever!! I can not get it to line up or angle in for anything. I must have tried for 2 hours straight. It is an 03 evo 8 can someone please give me some tricks they used or simply what will work.
Thanks guys!
Old May 16, 2013 | 04:02 AM
4RETECH's Avatar
Make sure your roll stopper bar is out, and of course your TCase so it doesn't bind going in.
But since I don't know what part of the process your at please let us know so we can help.
Old May 16, 2013 | 04:51 AM
lostsoulsevo's Avatar
the hardest part really, which i think you're having is lining up the spline to the motor. the easiest way is to have 2 people. one person lining up the tranny to the block and the other turning the crank.
Old May 16, 2013 | 05:08 AM
DYTNEvo's Avatar
I will pay for anyones gas in the indianapolis indiana area to come help me. I am getting caught on the back side and the pressure plate
Old May 16, 2013 | 08:06 AM
DYTNEvo's Avatar
Come on guys any takers I'm desperate
Old May 16, 2013 | 08:51 AM
Ev0ikon's Avatar
The trick is to have the back end of the car a bit higher than the front.
Old May 16, 2013 | 09:14 AM
DYTNEvo's Avatar
What about lowering the block down
Old May 16, 2013 | 10:46 AM
blowngasket's Avatar
Yep lower the engine ALL the way, go in at a angle then up, Have the Crossmember Down so it clears it might even have to wedge it back a bit. The splines are jammed up r they? is it a twin disc?
Old May 16, 2013 | 12:32 PM
JJLANCER02's Avatar
have someone turn the crank so it can slip right in.
Old May 16, 2013 | 12:48 PM
DYTNEvo's Avatar
Someone shoot me a text so I can explain my problem. 765-993-8617
Old May 16, 2013 | 01:05 PM
twabtoxer's Avatar
It is a pain but doable... I had to keep lowering and moving the motor around till I found that sweet spot ... good luck bro
polish_pounder
17
May 31, 2014 11:19 PM
RallyRedRS
Oct 28, 2012 11:35 PM
