How to break in a brand new 4g63 evo 8
Old May 21, 2013 | 10:34 PM
barneyb's Avatar
When detergent oil was developed you always broke in an engine with non detergent oil. Now, with synthetic oil on the market you must break in an engine with detergent oil. You won't be able to use synthetic oil as a break in lubricant until a new product comes along.
Old May 22, 2013 | 06:39 AM
chu's Avatar
chu
The Amsoil Break-In oil is apparently good. Its an SAE30 weight oil, fortified with high zddp contents. They do not recommend it for the initial startup though becasue it would be a waste of money. But got the 1000 miles of street use, its not a bad idea. We're going to use that on my brother's 240SX which recently got rebuilt.
Old May 22, 2013 | 06:46 AM
gsrboi80's Avatar
AMSOIL and waste of money used in the same post
Dont say that too loud around here the sky may fall
Old May 22, 2013 | 07:07 AM
chu's Avatar
chu
Oh boy...
Old May 22, 2013 | 01:02 PM
evonh10185's Avatar
I've never ran amsoil I might give it a shot this time.
Old May 27, 2013 | 01:08 AM
MRaculous's Avatar
Someone already mentioned there is specific break in oil, sounds inexpensive compared to what you spent on an engine and worth it. These may sound corny compared to the other good pieces of advice above but I've always run these 2 products on new engines. They are cheap and why not:
FilterMag
I think RA300 is what I had on my EVO:
Also a magnetic drain plug bolt:
Hope those help, good luck with the new engine. Hope it's a monster.
Old May 29, 2013 | 06:33 PM
mines5's Avatar
I built my evo8 4g63 , have done 600 kms. The engine starts to feel heavy as the revs go past 3500 rpm till 4200 rpm. I didnt do the short acceleration burst. Mostly driven it between 2k till 3.5k rpm up till now with no boost.
Now ill start to give the motor some boost but i am worried about this heavy feeling.
Could this be caused by a very tightened timing belt ?
Old Oct 4, 2013 | 09:56 PM
boost556's Avatar
i am gonna bump this thread, same with me anyone has any ideas???
Old Oct 4, 2013 | 10:25 PM
sktng22's Avatar
you will never get a straight answer on how to because everyone does it differently. take in the posts and go with the one you feel works for you
Old Oct 5, 2013 | 05:26 AM
boost556's Avatar
I was referring to the heavy noise i am getting when i hit over 4k, sounds like the car is straining to get there, but it do and the exhaust noise seems way heavier at that rpm level than usual.I currently at 500 break in point ready to do another oil change and continue i was wondering could this be the timing belt needs adjusting? anyone please appreciate the FB!
Old Oct 29, 2013 | 05:51 AM
SloGST's Avatar
Did you set the tension correctly? Have you tuned your car? Mods?
Rom
Apr 20, 2017 10:57 PM
Evo Amzler
May 24, 2016 06:59 AM
theblackbeast11
May 23, 2016 04:16 AM
charmcdo
Sep 3, 2011 07:38 PM
vince_w2004
27
May 3, 2010 03:25 PM
