Bad ball bearing fp black????
Old May 31, 2013 | 08:28 PM
nwa7265's Avatar
I bought a Ball Bearing FP Black turbo off a guy on here warier in the week I put it on the car and I started it for the first time today. There is a loud whining noise coming from the turbo. I cracked the oil feed line to see if oil was goin to the turbo and oil came out so I know it didnt get starved of oil on this first start I also poured oil into the inlet of the turbo before I put the feed line on. The member said that it only has 75 miles on it.
What do you guys think bad turbo? Yes/no and if so what do you think it is?
Here is the noise at the first start up with idle and then. A video of of shut down.
Old May 31, 2013 | 08:58 PM
SLVRNBLK's Avatar
Veteran: ArmyFCOTM Winner
The whine doesn't sound normal to me. What I really noticed is when you shut the car off a ball bearing turbo should continue spinning easily and smoothly for long period of time before it gradually stops. Here is my JB FP Black.
Last edited by SLVRNBLK; Jun 6, 2013 at 07:48 PM. Reason: Video which shows JB spool
Old May 31, 2013 | 11:08 PM
nwa7265's Avatar
the car was cold when i finally let the car warm up it spins for a lot longer after shut down but it leaks oil out the compressor cover so there is something wrong with the turbo.
Old Jun 1, 2013 | 09:25 AM
SLVRNBLK's Avatar
Also, are you sure its a BB unit? One way to tell is right below the water/coolant line bolt, there should be a plug with an allen fitting. If its not, then its a journal bearing unit.
Old Jun 1, 2013 | 07:50 PM
nwa7265's Avatar
yes it is a ball bearing unit i called fp and they told me it was. there is a problem with the turbo because there is oil coming out of the compressor houseing while running. im sending it to fp on monday!
maxspeed96ct
18
Oct 18, 2016 01:44 PM
korzunm
Mitsubishi TC-SST Discussion
26
Nov 5, 2015 05:51 AM
honki24
Apr 16, 2015 09:06 PM
Tom n
12
Dec 9, 2013 07:20 AM
udomaki
Feb 3, 2013 09:11 PM
