Questions about the dreadful PO300 code?
Old Jun 2, 2013 | 03:53 PM
ctfpevoVIII's Avatar
Originally Posted by tiggeryellow1
Hmmmm maybe your MAF is dirty, or your 02 is on its way out. Def check with your tuner though bro.
When you go WOT isn't the o2 out of the loop? Anyways I will post what I come up with . Thanks
Old Jun 2, 2013 | 04:11 PM
Dynotech Tuning's Avatar
Here are the criteria for tripping the P0300:
PAGE 41
http://www.lilevo.com/mirage/EVO%208...05500C-13A.pdf
-Jamie
Old Jun 2, 2013 | 04:23 PM
Common issues I found to cause the P0300 are too cold of a spark plug heat range, too tight of a spark plug gap, poor quality air intake pipe on a MAF causing irregular low airflow turbulence and erratic fueling, and bad coils/wires.
-Jamie
Old Jun 2, 2013 | 08:43 PM
tiggeryellow1's Avatar
Veteran: Army
Nice. The win is coming out in this thread for sure.
Old Jun 2, 2013 | 10:09 PM
barneyb's Avatar
You are correct.
Old Jun 3, 2013 | 06:46 AM
Travis@GSC's Avatar
What are the spark plugs gaped to?
I would also suggest a retune for the S3s, especially after going from HKS 272
Old Jun 3, 2013 | 06:44 PM
The car was retuned for the s3's, when it doesn't miss it pulls very strong. I think it may be ignition related but wont know until it gets figured out. I'm running NGK BR8ES gapped to .018, I made them a little tighter because I was running them at .022 and thought maybe they were blowing out. Do you think the BR8ES are too cold and what gap do you recommend?
Old Jun 3, 2013 | 07:05 PM
.022" shouldn't have any blowout issues at your level, even on stock coils. 8's at .018" can definitely have some misfiring at idle and light cruise at times. More so with stock coils than with the non-CDI setup you have.
-Jamie
Old Jun 3, 2013 | 08:42 PM
NightHawk's Avatar
I had this CEL pop up 4 times over 4 years of driving my 03. 2 different shops said it wasn't anything to worry about, happened a couple times when I got on the car getting on the highway and a few from normal driving in 2nd-3rd. Only thing I never played with trying to fix this issue was the injectors. weird
Old Jun 4, 2013 | 12:46 PM
Travis@GSC's Avatar
.022-.024 should be fine. I would check every wire, connector,ground point possible, especially if it was touched when installing the cams. Ive seen a few wires pull out of clips for the coils and make loose connections that cause random issues.
Old Jun 4, 2013 | 12:48 PM
Travis@GSC's Avatar
and i would recommend a 7 heat range NGK plug
Old Jun 4, 2013 | 07:12 PM
I use to run BR7ES 's , you really think I would be ok on the 7 heat range? It would be less prone to fouling . Thanks
Old Jun 4, 2013 | 09:17 PM
JohnBradley's Avatar
I wouldnt say that GSC specifically causes the P0300. That code has been an issue in ALL Mitsubishis since 1995 and typically never has anything do with a real misfire. If you are actually getting misfires that you can feel, like hiccups in the car, and it throws the code that is different. Just getting the P0300 means nothing.
Get the car retuned for the cams (it definitely needs it), check for boost leaks, then turn it off and be done with it.
Old Jun 5, 2013 | 04:54 AM
Veteran: Army
Right but you WILL pay attention to it when it starts affecting the "act right" of your car and it becomes no fun to drive.
Old Jun 5, 2013 | 07:34 AM
He is talking about his car being dead rich, hasnt been tuned, and now has a code. The code doesnt make the car run crappy, its the other stuff that is doing that and it happens to throw the code as a result. The cause and effect are out of order here.
cognizio
Outlander Sport
May 28, 2024 06:38 PM
Smogrunner
Jun 26, 2017 03:54 PM
slowonder
Feb 26, 2017 01:58 PM
302Squill
Mid-Atlantic Region
Aug 21, 2015 09:22 PM
DJErickG
Feb 11, 2015 05:57 PM
