normal knock sensor reading
Old Feb 20, 2004 | 08:49 AM
cecilia's Avatar
Question normal knock sensor reading
sorry guys for the stupid question....but today this morning...i got on the highway and my knock sensor went to 4 reading rpms at 6,000....i got off the highway and then it read at 6.......after getting on the on ramp again it read at 12???? does that mean something is wrong?? and if i'm correct on reading is 48 bad? it hasn't reached that point yet but i just need someones opionion....
Old Feb 20, 2004 | 08:58 AM
MrBonus's Avatar
I'm assuming you're using an SAFC-II which is reading the ECU's knock reading. The knock sensor is very sensitive and just because it's reading knock doesn't mean your engine is necessarily pinging.
Of course, I'd be careful too. You might be running too lean or picked up some bad gas.
Old Feb 20, 2004 | 09:03 AM
cecilia's Avatar
well i run 91 octane over here in new mexico.....and i'm also using buschurracing's settings for the SAFC....
Old Feb 20, 2004 | 09:46 AM
Fourdoor's Avatar
What boost pressure are you running? 91 octane is good for about 20 psi (1.4 bar) with the EVO. You will periodically get a small amount of knock when the ECU advances timming a bit to see if you are running good gas, then it figures out you are running 91 and stops trying to advance the timming.
Keith
Old Feb 20, 2004 | 09:51 AM
mprtklr's Avatar
0 (most of the time)
will go to as high as 10 when idling for extended period or in S and G traffic
Old Feb 20, 2004 | 10:39 AM
stevEVO8's Avatar
Mine is at zero most of the time.... I do notice knocks as high as 13 - 14 After a long drive. (2-3hrs) these shouldnt be of too much concern. Most everyother time the car is at zero knocks.
I think the knocks after a long drive are due to the engine being fairly hot.
I would only worry about high knocks counts. Since alot of lower knock counts can come from almost anything as was previously stated.
Old Feb 20, 2004 | 12:17 PM
cecilia's Avatar
well i got on it after lunch and it knocked at 82 in 3rd gear and it redlined at 7643 can someone help me here!!
Old Feb 20, 2004 | 12:18 PM
cecilia's Avatar
i'm running 19 psi
Old Feb 20, 2004 | 01:29 PM
stevEVO8's Avatar
Is this something that has been happeneing with your current AFC settings?
Or is this something new?
Try getting some better gas, lowering your boost a little bit and see if that helps.
Old Feb 23, 2004 | 08:44 AM
cecilia's Avatar
now why would you wanna lower you boost!!
Old Feb 23, 2004 | 09:18 AM
stevEVO8's Avatar
Well If you knew what you were talking about you would attempt several things in your troubleshooting steps.
He would try lowering the boost to see if this reduces the number of knocks. If it doesnt than there maybee something else wrong with the car.
Maybee a faulty sensor maybee, the afc reporting incorrectly. Or it could be bad gas.
If you dont have any suggestions on how to fix an issue or to help this guy out than dont say anything at all.
Its people like you on this board that bring it down. Maybee by your rational this guy should turn his boost up to see if the issue goes away? He is having a knock issue which can be attributed to a lean condition in his engine. Turning down the boost will help better diagnose his issue.
Old Feb 23, 2004 | 11:07 AM
cecilia's Avatar
that guy is me you idiot!! and i'm not a dude!! it just doesn't seem right that your saying that boost should be lowered on a evo! boost goes up dude...not down.....you should know that...
Old Feb 23, 2004 | 11:08 AM
cecilia's Avatar
oh and don't talk **** to me if you just got an evo...i rather have a guy thats a little more technical than you.....since you barely got your evo
Old Feb 23, 2004 | 11:15 AM
Guack007's Avatar
Wow! Glad to see everyone had a good weekend.
Old Feb 23, 2004 | 11:20 AM
stevEVO8's Avatar
Ha your funny.....
Ive had two moddified turbo eclispes before the evo and been strictly modding mitsus for about 10 years (sounds like you have never had and experience with this or any other turbo charged car)... and if you knew anything about the car or turbo induction you would know that if he turns down the boost and the knocks go away then he is having a possible detonation problem (These can be attributed to bad gas, lean conditions, fuel delivery and many others that Im sure you know nothing about.)
Just because most other people have not had issues detonating with stock boost levels doesnt mean that he is not. There have been several other people on this board that have seen det on stock boost levels.
Turning up the boost on an evo that is not known whether or not it is detonating is asking for trouble. You have no idea whether or not the gas/boost pressure/knock sensor/or ECU are players in this equation.
Basic troubleshooting steps to eliminate all possibilities should be used to find out where his knock is comming from.
Sounds like you like to read a bunch of stuff that you know nothing about and then spout off. Maybee you should go and turn up your boost and see what happens.!!
