What to expect upgrading to r2s
Old Jun 9, 2013 | 07:03 PM
evoyrrah's Avatar
Boys...I have a 2.4lr fp black on pump gas setup and looking to get the most out of it. I currently have gscs2 cams and I'm wondering what gains (if any) I can expect out of upgrading to s3 or r2 cams? I can understand on e85 it would go crazy and make more power everywhere in the rev range but on pump gas??? Has anyone done anything like this?
Old Jun 9, 2013 | 09:12 PM
browningderek's Avatar
I just got mine installed and even at low boost I'm saw the AFR lean out 8% everywhere in boost over the Buschur cams I had. Which indicates an increase in power across the board with the r2 cams. From my calculations it would be safe to say the r2 cams will give a 4-5% increase in power everywhere over the s2 cams. So if you have 450whp it will give you an 18-22hp increase over s2's.
Old Jun 10, 2013 | 02:49 AM
sparky's Avatar
Originally Posted by browningderek
I..... saw the AFR lean out 8% everywhere in boost over the Buschur cams I had. Which indicates an increase in power (of) 4-5%....everywhere over the s2 cams. So if you have 450whp it will give you an 18-22hp increase over s2's.
Derek, are you running a 2.4L motor too?
Old Jun 11, 2013 | 04:26 PM
evoyrrah's Avatar
Bump
Old Jun 11, 2013 | 08:12 PM
batty200's Avatar
For cars that are more limited on boost by lower quality fuel's making the engine more efficient is the name of the game. It is a lot more expensive than cranking it up on e85 and the results are smaller. But cams and ported head plus intake and exhaust manifolds make a big difference.
Old Jun 11, 2013 | 08:38 PM
Mods are in my SIG. 2.3L
kinein
30
Mar 26, 2015 04:42 PM
FreshEvoEight
Mar 12, 2015 12:43 PM
bpellari
Evo X Dyno Results
25
Jul 29, 2014 07:56 PM
Spoolin18
32
Dec 9, 2013 07:36 PM
l2r99gst
May 30, 2009 11:48 PM
