boost leak test, gurgling in oil pan
Old Jun 10, 2013 | 01:16 PM
Czarcasm's Avatar
I wanted to check the system again by doing a boost leak test, sprayed all the charge pipe couplers, fmic, injector seals, tb and tb gasket. Heard a gurgling sound so I figured id trace it, opened the oil cap and the gurgling sound coming from the oil pan. Whats causing the air to go to the oil pan? Turbo seals going bad so its pushing the air into the oil thru the return line? Compression test tested good, I was tuned on 26psi and im not noticing any loss of power under acceleration. I put everything together and went for a drive, at wot im holding 26psi.
If im not blocking something off please post it here
There is no play in the compresor shaft
Old Jun 10, 2013 | 03:26 PM
ExViTermini's Avatar
I've seen it before but it was on a Comp turbo. I'd call PTE to confirm/deny whether it's good or bad.
Old Jun 10, 2013 | 04:18 PM
Czarcasm's Avatar
I just spoke with them and they said its normal.
Old Jun 10, 2013 | 04:20 PM
BEKevo's Avatar
Was the boost leak test performed while the motor was cold?
Old Jun 10, 2013 | 04:36 PM
Czarcasm's Avatar
No, it was warm
ChipperEvo
Jul 1, 2014 09:49 AM
Murder Snake
Jul 1, 2014 09:01 AM
fritobandito24
Lancer Troubleshooting
Aug 4, 2013 09:00 AM
Mitsu.kid.02
Aug 16, 2011 06:22 PM
Pick_a_Fro
Lancer Tranny/Drivetrain Tech
12
May 4, 2005 04:36 PM
