Need Help with Fuel Setup 800WHP
1450s and BR double pumper can supply 800+ on Q16, though I was spraying a little meth on top which gave me a little more injector (just the AEM 500cc jet). 400lph is more expensive to do correctly and doesnt have much more gains over the double pumper anyway.
You will need a double pumper for sure, I just picked one up and I am only in the mid 500hp range. Or you could do the internal pump with an external inline pump. I am upgrading my fuel line to 3/8" and using the OEM feed for the return but apparently this may be overkill.
I use to run dual bosch 044 on my civic making 790WHP with -10an feed and stock feed for return which worked great. If stock lines are capable of making 800 then I might keep them stock for now and upgrade on later date.
I have one 255lph and 400lph pump. I will see if buschur is willing to use my pumps and make me double pumper.
FS[Mid-Atlantic]: Total Part Out: 800WHP Evo 8
REV.olution
For Sale - Part Outs
42
May 27, 2014 01:03 PM
