Can I turn up the boost?
Old Feb 21, 2004 | 09:25 AM
Luffy's Avatar
Can I turn up the boost to 19 PSI with the stock fuel injectors and stock turbo?
Old Feb 21, 2004 | 09:29 AM
EVOlunchbox's Avatar
yes
Old Feb 21, 2004 | 09:38 AM
ttiscio's Avatar
I'm running the WORKS P2 reflash with 19 PSI of boost. Runs great!
Old Feb 21, 2004 | 09:43 AM
Luffy's Avatar
Thanks!
Old Feb 21, 2004 | 10:01 AM
NYEVO8's Avatar
does anybody know how hard the stock injectors are worrking at a steady 19 psic OR how much boost can the stock injectors handle before maxing out
Old Feb 21, 2004 | 10:47 PM
memo3's Avatar
19psi is completely safe... more than 22-23.. thats where you have to start worrying about
Old Feb 22, 2004 | 03:23 PM
EvoHopeful's Avatar
I run 20psi on my stocker. Now it feels like an evo. The car runs pretty rich out the box. So leaning it out by raising boost a little is no problem.
dang i need to turn into an evolved member soon. activate super posting mode.
Old Feb 22, 2004 | 08:13 PM
Trail Slide's Avatar
19-21 is safe , though if you go above 19 you'd probably be leaking boost on the stock bov , 22-24 is still technically safe.... but it is not good for your engine or turbo , therefor lessening the life of both..... i would not risk it , keep it highest 21 psi with stock internals
Old Feb 23, 2004 | 10:24 AM
nonmature's Avatar
heres a link on the injector duty cycles... it doenst tell you exactly what they are but it tells you an estimate of what they can handle
http://www.boostsolutionsinc.net/technical-injsize.htm
-non
Old Feb 23, 2004 | 02:14 PM
KFive's Avatar
Tuned @ 24 then drops off up top. At higher elevation we can run more boost to compensate for the less oxegen. So at lower elev. I'd be around 20-22 lbs.
heartagram88
14
Oct 5, 2009 11:45 AM
Derek888
11
Sep 25, 2009 10:07 PM
Derek888
Feb 2, 2005 12:32 AM
Derek888
32
Oct 18, 2004 01:22 PM
EVO VIII Chris
Jun 22, 2003 12:26 PM
