PCV Fail.... B.L.T 5psi~
Old Jun 21, 2013 | 07:26 PM
WRC-LVR's Avatar
Originally Posted by GotWheelHop
If he removes the pcv and plugs the port off the intake manifold as suggested, how exactly will he be pressurizing his crank case?? With a proper catch can setup you can delete the pcv entirely. I can't think of any aftermarket intake manifold that has a specific pcv provision or barb off the top of my head.
Yes you can do this. However blowby and valve seal leakage can and does pressure crankcases esp turboed . It is why you will find large multi hose -10 12 AN hose sytems on HO/racing IMSA cars to help evacuate and avoid pressurizing.
I use 2 catch cans. one on the turbo inlet with one way pcv valve to avoid pressure spikes coming back to the valve cover during back fires etc. Empty the catch frequently. 2 time a month. I DO not see oil in it 100 % water vapour only. 25 psi tapering to 23-22
PS the turbo pulls one hell of a lot of air under load and that includes from the front breather hose.....bigger is better as long as you trap any oil..dont want that to get to the cylinders and up the temps we all recognize that
My other can is on the pcv from the intake manifold. This operates in low load to pull oil vapours and burn blow by as well. Lowers overall emissions venting and keeps the crank case cleaner.... shuts to stop pressurizing.
This one i dump about 1 a month and i get about 90% water 10% oil. IIRc that is because of the location of the pcv valve and the oil near the front of the head.
Yes you can eliminate the pcv. I use them and breather tanks Why not keep the engine crank case cleaner and more compliant ?
Old Jun 25, 2013 | 07:00 PM
mrfred's Avatar
The 3rd party PCV valves blow. I've tested them, and they all leak badly. The OEM PCV valve is great though. Seals up perfectly in my testing. Clean it and reuse it, or go with an inline check valve in the hose. One thing to watch with the inline check valves is that the crack pressure for most of the inline check valves is too high. You want one that has a crack pressure of no more than 0.3 psi.
Old Jun 26, 2013 | 02:06 PM
bbong's Avatar
I use stock PCV going from the back of the head to the catch-can, then from catch-can to intake manifold I use this PCV: http://www.usplastic.com/catalog/item.aspx?itemid=23369, so I don't pressurize the catch-can during positive pressure inside the mani.
EvoIX89
17
Sep 22, 2015 07:11 AM
Johnboy1065
12
Feb 9, 2009 06:24 AM
sabastian458
Dec 11, 2008 12:31 PM
dudical26
26
Jul 25, 2007 02:25 PM
BluEVOIX
Apr 3, 2007 11:52 PM
