FP black on stock injectors??
Old Jun 19, 2013 | 08:13 PM
xXevo8RavenXx's Avatar
looking to do another evo build and was wondering if the stock injectors on a 255 walbro will work for 25psi on a fp black??
Old Jun 19, 2013 | 09:09 PM
evo8lento's Avatar
Not an expert by any means but don't expect to get much out of it. Timing will probably be pretty low (?)
Old Jun 20, 2013 | 04:32 AM
anymore input guys?
Old Jun 20, 2013 | 04:49 AM
evo8426's Avatar
If you want to be capped at ~380whp then yes they will work.
Old Jun 20, 2013 | 06:23 AM
minimarine09's Avatar
^^^ that. I was out of juice at 360 to the wheels on stock injectors at 95 idc. With the stock turbo at 23#s. Get some much larger ones. my guess is you are planning on staying with 93 pump? You will prob max out that Walbro 255 at around 500hp. I would Get like 1000cc-1200cc and call it a day. If you are doing e85, get a double pumper and like 2000cc+ injectors and call it a day of you are looking for alot of power. Just my.02!
Old Jun 20, 2013 | 06:31 AM
binky's Avatar
I ran out of stock injectors (118%) on my stock Evo VIII turbo.
You will definitely need bigger injectors to use the FP Black safely and properly.
-Bink
Old Jun 20, 2013 | 11:19 AM
jspecteggy's Avatar
There's a couple threads for ID 2000's FS in the Marketplace right now.
Old Jun 20, 2013 | 11:38 AM
MR. EVO MR's Avatar
If you add meth you can still run stock injectors
Old Jun 20, 2013 | 11:58 AM
heel2toe's Avatar
Limiting the power you make due to the injectors is silly IMO. You'll be adding ~1000RPM of lag and making the same power as the stock turbo. What's the point?
Old Jun 21, 2013 | 08:19 AM
Pssst's Avatar
Yeah seriously... I have 850's on mine(will have new ones soon) and they are like 98% duty cycle and my boost is starting at 4500....
I put down 433awhp on a mustang dyno with my build. I couldnt imagine using stock injectors, that car would be boring as hell, heck, it'd be a regular lancer untill like 5500 when it would start to spool...
09Ralli
Oct 13, 2016 02:09 PM
Duh Panda
Apr 26, 2016 10:58 AM
Nadaevo
Mar 3, 2016 06:28 AM
scothu
16
Feb 16, 2014 04:50 AM
tim85851
Dec 25, 2009 01:18 AM
