GSC R2 Cams results?
Old Jun 22, 2013 | 03:45 PM
rs03evo's Avatar
I've been looking at purchasing a set of GSC R2 cams for my 8 RS and a was wondering if any one is running them on their Evo 8??
Old Jun 22, 2013 | 05:28 PM
brokenRS's Avatar
R2 is recommended for a stroker motor, judging by your sig mods you should be able to pick up some nice gains!
Old Jun 22, 2013 | 06:24 PM
JohnBradley's Avatar
2.4 with some good headwork will definitely benefit from the R2 set. What results were you looking for specifically, back to back or just a 2.4 with R2s?
Old Jun 22, 2013 | 07:33 PM
Benja's Avatar
You still seeing worthwhile gains on stock head JB?
Old Jun 22, 2013 | 08:11 PM
rs03evo's Avatar
Back to back would be awesome... I saw the thread you guys did a while back but it was on a Evo 9 if I remember correctly.. its hard to find any review on these cams for the Evo 8 I guess cuz they are so new...
Old Jun 22, 2013 | 11:02 PM
browningderek's Avatar
I'm doing a back to back soon. Results will be up.
Old Jun 23, 2013 | 11:18 AM
rs03evo's Avatar
awesome.. If its not to much trouble could you post a idle vid.. I've heard they sound nasty
Old Jun 23, 2013 | 05:22 PM
Fireescape's Avatar
Just drove my stock 2L Evo 9 with newly installed R2's, FP Black and Speed Density for the first time last night since the install. Sound wise I can hardly hear a difference from OEM, maybe slightly lumpier. Just have a base SD tune from Tom at TSComp at this point, no tuning done, but the car already feels smoother. As far as I can tell the R2's work fine on a stock 2L motor, I do have some mild port work on the head and 5041 springs/retainers and new GSC valve stem seals, we will see how things go when I get the car tuned. Not sure if there are any benefits going with the R2's over say S2's, but I'm sure their not going to hurt the power output, Mr TSComp doesn't think so anyway. Cheers
Old Jun 24, 2013 | 01:15 PM
Will do! It sounds like a damn rx7.
Old Jun 24, 2013 | 02:07 PM
Grimgrak's Avatar
https://www.evolutionm.net/forums/10649070-post22.html
Old Jun 24, 2013 | 03:21 PM
rs03evo's Avatar
That's almost the same exact words that were used to describe the R2s from another member
Old Jun 24, 2013 | 08:13 PM
R2s in an VIII are a slightly smoother (I use this loosely) version of the S3 as far as idle. They havent seemed to hurt spool much, just pick up power out the top. On a stock head and FP Red we found 25whp (thru an Auto) on that 2.0L IX over S2s so if I had to wager I'd think a mildly worked head would see another 10. Converting back to 5 speed that would put it in the 40s.
midegade
Mar 22, 2017 04:17 PM
EVO 4 life
Dec 3, 2016 07:29 AM
Rectzero
Aug 10, 2016 01:56 PM
Alexevo09
Apr 27, 2016 02:16 AM
krahman95
Dec 11, 2015 10:20 AM
