Exhaust leak at catback, help!
Old Jun 25, 2013 | 05:48 PM
slc_evo69's Avatar
So I just installed a test pipe to accompany my greddy to-c catback, and ever since i have a persistent exhaust leak that I can't seem to get to go away. I have a brand new grimspeed gasket in place and it doesnt seem to be working. I have tightened both flanges as much as possible and still nothing! Where do I go from here? Gasket sealer?
Old Jun 25, 2013 | 05:59 PM
sujinX's Avatar
Gasket sealer. I need to pick up some myself.
Old Jun 25, 2013 | 06:03 PM
slc_evo69's Avatar
does gasket sealer make it difficult to remove the exhaust later on down the road?
Old Jun 25, 2013 | 06:05 PM
slc_evo69's Avatar
And is doubling up on gaskets at a single connection a bad idea?
Old Jun 25, 2013 | 07:20 PM
w33zy's Avatar
Would like to know as well, because I am replacing the gasket on mine tomorrow..should I go with gasket sealer just in case?
Old Jun 25, 2013 | 07:42 PM
evobros's Avatar
I always put grey sealer after an exh swap.
Old Jun 25, 2013 | 08:17 PM
PureDrivePerformance's Avatar
Do you know it's at the test pipe? Once I put my cat in and I got a leak at the top of the DP. I had to adjust it and it was fine.
Also, isn't the grimspeed gasket pretty thick? Any pics of the leak?
Old Jun 25, 2013 | 08:45 PM
slc_evo69's Avatar
I'm positive it's at the test pipe, cuz I can feel it by reaching my hand under and feeling it. It's on the top part of the connection, the bottom half seals. And yeah they are pretty thick gaskets, got em' from rallysportdirect here in Salt Lake, brand new.
Old Jun 25, 2013 | 08:47 PM
slc_evo69's Avatar
I'm starting to think I'm just going to use some gasket sealer tomorrow. Did some research and everyone says it works great, as long as you get stuff that is capable of the heat.
ChipperEvo
Mar 31, 2020 10:23 PM
Evo47
Mar 10, 2016 10:27 AM
Carnifex
Jun 22, 2015 09:29 AM
EvoRinga
Mar 12, 2012 07:39 PM
willum14pb
Sep 3, 2006 12:39 PM
