pocket logger question
Old Feb 22, 2004 | 05:43 PM
rt turbo's Avatar
anyone running this from www.pocketlogger.com? i just bought a palm pilot m100 on ebay and im making sure i need to obdII harness and software from pocket logger. ive been looking at this for a year now, i hear no complaints. now that im making crazy power i need some sort of knock logger. how are everyones thoughts on this fine piece of electronics?
-Andy V.
Old Feb 22, 2004 | 05:52 PM
992gnt's Avatar
Yes you need the cable and software . I've been using it for a couple of years now with no complaints. You do know that ODBII doesn't have a knocksum output, right? If you want to log knock, you'll need an add-on like the J&S unit or the SAFCII. Neither of them log knock the way the ecu sees it though. There will be a correlation between "real" knock and knock sensed by one of the previously mentioned units, and neither (AFAIK) will retard timing based on what they see.
Old Feb 22, 2004 | 06:57 PM
jemm's Avatar
What solutions for Pocket Pc (iPaq) do you recommend?
Thanks
Old Feb 22, 2004 | 10:09 PM
rt turbo's Avatar
so it doesnt show knock at all? it says on the web site it does.
Old Feb 23, 2004 | 12:19 AM
1QWKEVO's Avatar
the OBD II doesn't log knock.... I ahve used this setup on my evo and found it to work great, you can monitor knock by watching timing... when knock occurs timing will fall flat and not climb back up... normal patterns of timing are under boost/load, timing will fall but then rise, when knock occurs the timing will continue to fall, or stay flat...
If you interested in a used Pocketlogger harness and software let me know. I'm no longer using mine, PM me
Old Feb 23, 2004 | 12:43 PM
justchil's Avatar
I'm very interested if Palm OS is not required.. I've got 2 PDA's running pocketpc2002 and pocketpc2003..
Old Feb 23, 2004 | 11:11 PM
rt turbo's Avatar
yes, i will buy that stuff from you if possible. it does work on the evo right? and its ganna be stilll good if used? thanks,
-Andy
Old Feb 24, 2004 | 02:21 PM
justchil's Avatar
I'd just like to know exactly what software will work with pocketpc or a laptop... and what cables I would need to use this on my EVO.
Old Feb 24, 2004 | 03:16 PM
1QWKEVO's Avatar
i have some TMO software for the laptop, but for some reason i can't get it to log anything, it works fine on non OBDII cars i'm not sure whats up but it was free software
