Getting oil on my windshield
Old Jul 10, 2013 | 09:35 PM
diponyou's Avatar
So I havent put many miles on my evo since driving it, and I wash it a lot whenever I do so I never noticed this before.
After maybe 400 miles there is a distinct oil spray mark on my passenger side windshield.
I noticed some oil on the front of my valve cover as well but just a few small spots that acquire after some miles.
Any ideas?
I can take a pic if needed
Old Jul 10, 2013 | 10:48 PM
batty200's Avatar
Sounds like a popped out dip stick. Put a hold down spring on it or zip tie it so it doesn't happen again.
Old Jul 10, 2013 | 11:06 PM
diponyou's Avatar
ill go check...
well the dipstick was sealed and seated quite well
and there is oil on the front of the valve cover which leads me to believe there is oil seeping from somewhere up front
Old Jul 10, 2013 | 11:28 PM
Pure EvoIX's Avatar
Sounds like blowby. I would wipe everything down in the engine. Go for a drive and pull over, check to see where the oil is coming from.
You might need an oil catch can or a proper oil/air seperator catch can.
Old Jul 11, 2013 | 02:29 PM
diponyou's Avatar
yeah this is what I was thinking as well
I will eventually get a catch can and see if that helps
previous owner put one of those filters on the valve cover and its probably spraying out of that.
Old Jul 12, 2013 | 09:26 AM
tsidrift1's Avatar
Originally Posted by diponyou
ill go check...
I would say sounds like a dipstick as well, but you said it was sealed into the tube.....I dunno what can be spraying oil onto the windsheild.
Old Jul 12, 2013 | 09:28 AM
donzilla2004's Avatar
possible cracked valve cover?
Old Jul 12, 2013 | 07:13 PM
AlmostHadMe's Avatar
can't be the dipstick then, I'd say what ^ he said, possible cracked valve cover. other than that i'm stumped, i've never heard of oil spraying onto the windshield, very curious to find out what is causing this..
Old Jul 12, 2013 | 09:46 PM
diponyou's Avatar
hmmm never thought about the valve cover being cracked?
is this something common with evos?
edit...just looked it up, apparently it is quite common. ill go check that out tomorrow
Old Jul 12, 2013 | 10:02 PM
joseph143's Avatar
Go to autozone... By the ac crap there with be dye additives. Find the one for engine oil. Add it and put a few miles on it. The spot that glows the brightest or the highest is the area to search...
Old Jul 12, 2013 | 10:11 PM
diponyou's Avatar
good idea
Old Jul 13, 2013 | 09:04 PM
MyronGainz's Avatar
I'll put money on the oil coming from there. Just re-route it back to your intake tube and see if it still happens, or get a catch can
Ferp
Jul 12, 2015 03:49 PM
jgevox
Jul 22, 2013 05:02 PM
WolvieDC
Jul 6, 2009 04:34 PM
CmakEVOX
Midwest Region
Sep 24, 2008 09:06 PM
BOOSTEZ
South Region
37
Sep 16, 2008 04:56 PM
