Evo 8/9 on road course - fuel starvation common?
@kikiturbo hey, that looks like that should do it. any of these for sale yet? no need to drop the tank to install I hope
will that transfer pump be fine if/when its fuel starved turning the other way? was thinking of using a low pressure fuel pump for carbs but the reliable ones are quiet noisy
that might not be a bad feature since I would only turn it on on track
isnt there no way to block the fuel sloshing at the hump with some foam? (no idea what it looks like in there)
that might not be a bad feature since I would only turn it on on trackisnt there no way to block the fuel sloshing at the hump with some foam? (no idea what it looks like in there)
Those don't need heat shrinked, they need to be rebuilt. The braid should be inside the fitting nut. Possible you used incompatible hose/fittings and you may different hose or different fittings.
you need to tuck/shove the cover under the fitting with a screwdriver before twisting it
Cant stop the fuel sloshing because you cant really access the inside of the tank.. both openings where fuel pump and secondary pickup sit, are enclosed with a small "bowl" inside the tank.. so cant really put any foam inside...
I did use RaceFlux fittings on Vibrant hose so you are probably right about that because the 8AN above the 10AN that is my rail return to the surge tank is RaceFlux fittings and hose which went together effortlessly in comparison to the vibrant hose. I will just get a little extra when I build out my feed and return lines on the rail end to redo those 2 lines.
@nightowl1985 @kikiturbo would it work if I have fittings right on the drain plugs and use a transfer pump ? I have an extra inline low pressure fuel pump from my carbureted car
I actually have the fittings already installed ... its lame since its too slow to drain
If you are after eliminating fuel starvation surge tank is the best way because its constant overflowing and returning back to the tank so the pump or pumps supplying the fuel rail is always submerged in fuel.
