Radiator slim fan
Below are the specson the fan . For examople if I'm drivng around the city the car does not overheat at all once I come to a stop light and stay there for 1-2 mins the temp starts to rise a little bit not too much though, when i get moving again it goes back to normal temp . Water pump , headgasket, thermostat are all new in good working order. As far as the fan being wired correctly I would say yes because it turn ons just fine . Should the blades be spining clockwise or couter cloickwise?
Mishimoto Slim Electric Fan 12"
CFM
933.5
Fan Diameter
280mm
Fan RPM
2095
Number of Blades
10
Current
~8A
Volts
12.25V
Amps
5.7
Velocity Ft/Min
724
Inlet Pressure While Tested
-0.04
Air Temp While Tested
62.6 (degrees F)
I DONT KNOW IF IT WOULD BE A GOOD IDEA TO ADD ANOTHER FAN IN FRONT OF THE RADIATOR SINCE I DONT HAVE AC AND I HAVE ENOUGH OF SPACE TO MOUNT A 10' FAN? ONE FAN PUSHING AND THE OTHER ONE PULLING ?
CFM
933.5
Fan Diameter
280mm
Fan RPM
2095
Number of Blades
10
Current
~8A
Volts
12.25V
Amps
5.7
Velocity Ft/Min
724
-0.04
62.6 (degrees F)
You need to make sure that if the fan is on the engine side its pulling air thru and if its on the bumperside its pushing air thru the radiator.. get a piece of paper , ribbon, something and wait for the fans to come and put it in front of the radiator. The paper should pull into the radiator--if its blowing away, swap the wiring, you have them backwards and the blade will spin in the opposite direction. If this doesnt work check with the fan man website for a Spal fan, I think mine pulls 1200 cfm at 5v or something like that. just a thought good luck.
I have a small radiator and slim fan . the radiator is located right next to the upper intercooler piping area.
dubbleugly01
41
Sep 23, 2016 12:07 PM
BrandonIX
15
Jun 12, 2016 08:17 PM
<mojo>
Lancer Troubleshooting
12
Nov 12, 2012 02:07 PM
