Evo 4 to 8 swap: no fuel/no ac fan
Old Aug 11, 2013 | 11:05 AM
Dvolution's Avatar
Swapped a VIII engine and ECU into my IV. Made a conversion harness for the ECU with an extension harness.
Swapped Pin 8 and 22.
Connected Vehicle Pin 20 to ECU Pin 32 for AC Fan High
Connected Vehicle Pin 21 to ECU Pin 34 for AC Fan Low
Disconnected Pin 87
Disabled the immobilizer
I have no fuel pressure and my blower motor does not work. I just double and triple checked my wiring and it is correct, but with the problems I'm having, everything is pointing to a wiring issue. All my fuses are good.
Any tips or advice?
Edit : Hooked up the VI ECU that was on it before and it started.
Old Aug 12, 2013 | 05:17 AM
wreckleford's Avatar
The problem would seem to be with 8 and 22. Check that you swapped the right pins. If it started with the 6 ECU after you did the pin swap then you swapped the wrong pins. You can verify the fuel pump wire by pulling the pin, turning on the ignition and manually grounding the wire and see if thre pump runs.
Old Aug 12, 2013 | 12:00 PM
robin-evo6rs2's Avatar
don't aks me..
eudm ecu are pin 22 and 8 reversed.
My eudm lhd VI wont start with a jdm tme ecu.
So maybe you got that going on.
Old Aug 12, 2013 | 12:58 PM
Dvolution's Avatar
Has anyone else run into issues with USDM computers not working with EUDM engines?
JDM vehicle
EUDM engine
USDM computer
and they don't want to work together.
Its like world war 3 in my evo
Old Aug 12, 2013 | 09:17 PM
Originally Posted by robin-evo6rs2
don't aks me..
Yes, I've played with an RS2 and pins 8 and 22 are like the US Evo 8. They also come with an immobilizer too.
Old Aug 12, 2013 | 09:18 PM
94AWDcoupe's Avatar
I tried evo 8 ecu in my 4 years back. if I remember correctly 8 and 22 does not need to be switched.
Old Aug 12, 2013 | 09:20 PM
JDM vehicle
EUDM engine
USDM computer
It will always work once you have the pins correctly located. Firstly the engine doesn't matter. With regards to the ECU and the vehicle, I've done about 10 USDM ECUs into Evo IVs. As I said before just confirm which pin is which and put them in the right places.
Old Aug 12, 2013 | 09:21 PM
I've had to switch them on every one I have done. If you use a 7 ecu you don't have to switch them however.
ahmedshaikhani
Aug 24, 2021 10:24 PM
TGC_QS
16
Apr 25, 2020 08:37 AM
3VOLUTIONIST
Mar 23, 2015 08:29 PM
mko
Jun 21, 2009 08:31 AM
