MIL Eliminator
Old Feb 24, 2004 | 12:26 PM
YEVOVIII's Avatar
MIL Eliminator
Where can I purchase one for the EVO???? I have looked at VIVID, KASTLEKORNER,LANCERSHOP but to no avail!!! Please help
Old Feb 24, 2004 | 01:33 PM
Fourdoor's Avatar
If I knew what "MIL" was perhaps I could help you out!
Keith
Old Feb 24, 2004 | 02:10 PM
EVO8speed's Avatar
found this on a web site, its for my VW
What is O2 sensor simulator?
The OBD-II cars (1996-1998) have the two O2 sensors to measure the amount of oxygen in the exhaust gas. First sensor is measuring it right after gases escape engine and this data is used to adjust fuel trim of the engine, as well as catch some faulty conditions. The second sensor is located after the catalic converter, and is used to detect the health of catalic converter. The ECU expects the signal from the sensor to be oscillating from below 0.4v to above 0.6v, but not above 1.2v, every few seconds when cruising.
If you install the aftermarket downpipe with no cat (which as we all know is purely for off-road applications) the ECU will detect this and indicate the error (MIL). The ECU is quite lazy at detection, and detects this condition approximately during second long trip. You can reset the ECU to clear the error code, but it's very inconvenient, as you don't really know if the error was because of oxygen sensor or some important thing is wrong and needs to be taken care of ASAP. It's also quite annoying
but www.casperselectronics.com might have something for the EVO, if not email them, they can make one. they have some for most cars, i'm about to get one for my VW.
sorry put the wrong web site at first!
Old Feb 24, 2004 | 02:16 PM
EVO8speed's Avatar
they also call it a O2 sims, i assume this is what your talking about? hope it helps
Old Feb 25, 2004 | 10:34 AM
fimotorsports's Avatar
perrin has one, not sure if they sell separte from there cat delete though
Old Feb 26, 2004 | 06:32 AM
EVO8speed's Avatar
check the site above, or email them, they can make one.
Old Apr 13, 2004 | 01:09 PM
Dutch's Avatar
Unhappy No such luck
I called casper's and they said they have nothing for the EVO right now, including an o2 simulator. They said they were working on it, and to check back mid-summer.
Anybody know of any other place that could hook someone up with one of these sensor sims?
Thanks!
Old Apr 13, 2004 | 04:01 PM
USP45's Avatar
There is a thread on here that is recent about how to get rid of the CEL caused by the O2 sensor. Look it up, but basically you take an 18mm spark plug anti-fouling extention and drill the end out to .5" and then screw it in to the exhaust and in turn the O2 sensor into it. I did it last week and so far I have 400 miles on it with NO cel. It works great!
Old Apr 13, 2004 | 04:16 PM
992gnt's Avatar
What he^^^^ said. I did the same thing, no CEL for 2-1/2 weeks now.
Old Apr 13, 2004 | 04:30 PM
EvoMike03's Avatar
can you provide a link to the thread?
Old Apr 13, 2004 | 04:47 PM
Dutch's Avatar
I Found that thread; searched for "18mm spark plug"...
https://www.evolutionm.net/forums/sh...threadid=62524
Old Apr 13, 2004 | 04:58 PM
nabit's Avatar
Here is one if you like DIY STUFF... http://www.rodney.chalker.com/o2_simulator.htm
reliablefr
18
Aug 30, 2012 11:46 PM
06RS
Jul 11, 2007 06:57 PM
