how to use stock feed as return?
Old Aug 17, 2013 | 10:02 AM
Jsiebert's Avatar
Ive got my new feed line and rail, afpr, and the proper fitting and line to run from my regulator to the stock feed and make it a return. How do you connect it to the pump housing? I tried using the efi clip on the feed line and the plastic hose just kinks.... is there another way to do it?
Old Aug 17, 2013 | 08:50 PM
okevolutionVIII's Avatar
On the drivers side right before the gas tank under the car, the 2 smaller diameter fuel lines and 1 EVAP line curve up and run to the top of the tank. Using a normal 5/16" fuel line and clamps, just switch the lines from under the car. If you click the link in my sig, I have pics of my fuel cell setup and have a close up of the 2 lines that would need to be switched.
igo4bmx
Oct 1, 2016 12:06 PM
BrownSuga
Sep 28, 2016 03:56 PM
Biggy VIII
Aug 9, 2016 03:06 PM
mrm95
Mar 11, 2016 09:43 AM
diablo1
Jul 14, 2011 08:46 PM
