blocking off stock oil feed line how to?
Old May 11, 2010 | 11:31 AM
igo4bmx's Avatar
I'm running a custom turbo setup- i need to block off the stock oil feed line so I can feed my t3 based turbo off the head port.
what bolt size do i need to accomplish this?
Old May 13, 2010 | 05:54 AM
JakeTheVIII's Avatar
Remove the stock oil feed line and use a new one in it's place.
Old May 13, 2010 | 06:39 AM
buchnerj's Avatar
http://store.forcedperformance.net/m...Lancer-TurboHW
This will give you the block off and having fittings to get a high flow line coming from the filter housing.
I am not sure on the size of the bolt, I am looking through the manual for you, but you could call FP and ask too. I am sure someone here knows the answer though.
Old May 13, 2010 | 06:53 AM
gsrboi80's Avatar
This. I just used new line that came with turbo to stock feed location
cssaddictm4's Avatar
It's 10mm x 1.25, if I remeber correctly.
Old Oct 1, 2016 | 03:26 AM
maxspeed96ct's Avatar
Can anyone confirm the length and size ?
I Recieved a FP oil line with the used turbo I purchase but I'm missing that bolt.
Old Oct 1, 2016 | 12:06 PM
MasterNater's Avatar
10mm x 1.25 is the correct size banjo bolt for the oil feed line at the head.
thepoint4life23
Jul 10, 2017 04:56 AM
BrownSuga
Sep 28, 2016 03:56 PM
Biggy VIII
Aug 9, 2016 03:06 PM
EvO_essence
14
Jun 21, 2016 11:47 PM
kaj
Mar 25, 2016 11:46 AM
