Evo throttle body clean up
Old Aug 30, 2013 | 06:23 AM
steven121's Avatar
Took apart the throttle body to replace seals, cleaned out the inside and outside. Put it back on abd started it up. Rev limit goes to 2k then to 1500rpm adjusted the throttle cable to get rpms to 1000. Car now feels sluggish not sure ehat to do at this point
Old Aug 30, 2013 | 06:36 AM
GTijoejoe's Avatar
Did you put the spring back in correctly?
Can you read the TPS % at idle with evoscan?
Old Aug 30, 2013 | 10:24 AM
steven121's Avatar
Yes, havent tried that yet ill do it tomorrow. What is it suppose to read
Old Aug 30, 2013 | 10:38 AM
wang4u's Avatar
Roughly 13.33% at idle, +/- 2% seems pretty common.
Old Aug 30, 2013 | 03:15 PM
steven121's Avatar
Ok should i put the cable bracket back
To where it was and adjust the tps? Or afjust the cable bracket?
Old Aug 30, 2013 | 04:16 PM
steven121's Avatar
Let me also add I did clean the entire throttle body, and the TPS is idling around 13.77 which is acceptable. So either i need to adjust the biss screw or retune the throttle body
Old Aug 31, 2013 | 12:24 PM
awdordie's Avatar
If you cleaned the tb with any kind of cleaner that was your first mistake. The black soot looking stuff behind the butterfly is not ALL soot. Some of it is a coating that helps seal the plate and help control idle.
https://www.evolutionm.net/forums/sh...d.php?t=540873
Old Aug 31, 2013 | 02:33 PM
steven121's Avatar
Yea thats what I did... Great
Old Sep 1, 2013 | 08:49 AM
GTijoejoe's Avatar
I've cleaned my TB and didn't have your issues.
Old Sep 1, 2013 | 02:19 PM
steven121's Avatar
I literally scrubbed every nook and cranny in my throttle body completely clean took off that gray stuff
parralegend
Sep 2, 2012 05:11 PM
ron2003
Aug 5, 2011 10:19 PM
shawnhayes
15
May 1, 2011 08:40 AM
heavens turbo
12
Apr 16, 2010 07:19 PM
orangeorphan
Dec 3, 2008 05:39 PM
