Introducing a New ACD Controller, ACDPro
Old Sep 4, 2013 | 07:04 PM
ACDPro's Avatar
Hi,
I are very happy and excited to introduce ACDPro Universal Controller an
aftermarket standalone Automatic ACD controller for JDM and USDM Mitsubishi Lancer EVO 7/8/9.
Have you swapped the transmission in your EVO or the stock controller is not responsive enough and need to control the ACD?
This product is specifically designed for swapped transmission cars, and includes everything required for automatic and manual ACD operation, including an advanced hardware and software design of the custom control module in a water resistant enclosure, with a nice adjustment knob for setting the locking force, this system is infinitely adjustable between fully active and inactive levels.
To read more about our ACDPro please go to the following link on our website:
http://proacd.com/products/
We have a limited time sales promotion to celebrate our product release.
Don't miss it.
Kind regards,
ProACD.com Team
Old Sep 4, 2013 | 07:11 PM
Raptord's Avatar
This is very interesting, and I'm pretty close to you guys too... Tempting...
Being local, can I try it out before buying?
Old Sep 4, 2013 | 07:21 PM
ACDPro's Avatar
Hi Raptord,
We have a 60 day return policy. If you send me an e-mail with your contacts to sales@proacd.com, I am sure we can work something out.
Old Sep 4, 2013 | 08:08 PM
Raptord's Avatar
Email sent
Old Sep 5, 2013 | 08:15 AM
Dallas J's Avatar
Veteran: Army
Awesome, so I take it you were able to get the pump and pressures figured out?
Old Sep 5, 2013 | 08:46 AM
211Ratsbud's Avatar
Does acd heavily bias the rear? I had an sti swap so I know that does but I always read the acd is 50/50 with variable lock .
Old Sep 5, 2013 | 10:57 AM
HDA's Avatar
HDA
Interesting:
Fully CCW turns the unit essentially "off" which will heavily bias the rear wheels, full CW gives it full "aggressiveness" maximizing traction and thusly increasing under-steer. In this setting the system will attempt to give you maximum traction at all times by trying to maximize the amount of ACD lock at all times.
Does it mean that Full CCW will give it all to the RWD?
Have you guys done some miles of testing to check that...nothing breaks?
Old Sep 5, 2013 | 01:02 PM
ACDPro's Avatar
Hi Dallas,
Good to hear from you. Yes we got the pump and pressure sorted out a short while after talking to you on an EVO 7.
Old Sep 5, 2013 | 01:21 PM
ACDPro's Avatar
Yes the ACD is a different concept. Basically it increases the clamping force that keeps the differential from becoming an open differential. Now when a slippage is detected the pressure is applied to plates that increase that force hence locking the two axles longer to gain stability.
In the literature when we talk about "active" or "lock" it should not be interpreted as distribution of torque rather it should be read as clamping force. Hope this explanation helps.
Old Sep 5, 2013 | 01:28 PM
ACDPro's Avatar
Originally Posted by HDA
Interesting:
As I mentioned in the previous post when ACDPro is at minimum setting (manual mode)
the forces applied to clutch plates that control clamping forces are non-existent. The
differential plates are in the resting state as you would have while cursing and there is no issue with wear or need to test at long distances as it is designed and tested by manufacturer for this state of operation.
Old Jan 16, 2014 | 08:24 AM
211Ratsbud's Avatar
Bump anyone try this out with a review on here ?
Old May 15, 2014 | 09:08 PM
211Ratsbud's Avatar
bump looking for people who have used this
Old May 18, 2014 | 02:36 PM
KenPeak's Avatar
Subscribed, interesting info
Old May 19, 2014 | 12:29 AM
211Ratsbud's Avatar
Would love to see more feedback on this! Would also like to see the user interface for USB tuning.
Please discuss the one time charges etc aswell: 495 +150 (+120??????) no comprendy.
Force-Fed Performance
35
Aug 2, 2011 06:02 PM
chiihuey
Toronto Lancer Club
Jun 30, 2011 04:45 AM
Noob Sauce
Mid-Atlantic Region
23
Jun 13, 2011 06:54 PM
purebredmutt
Mar 27, 2009 07:41 PM
