Switch from Neutral to first without engaging clutch?
Old Feb 26, 2004 | 08:59 AM
snoop's Avatar
Today I noticed that I could put my car into first gear without stepping on the clutch while the car was parked. I was concerned so I drove around parking lot and tried the same thing again but this time the stick didn't move. My car works fine and I don't have any gear grind when shifting gears.
Has this problem occured on anyones car?
Old Feb 26, 2004 | 09:01 AM
alfredob1's Avatar
With the engine running? If not, then that's normal for any gear.
Old Feb 26, 2004 | 10:25 AM
snoop's Avatar
The engine was on.
Old Feb 26, 2004 | 10:31 AM
nastea's Avatar
sychros?
Old Feb 26, 2004 | 10:44 AM
exhaust_note's Avatar
didn't the car stall as soon as it slipped into first
Old Feb 26, 2004 | 01:07 PM
snoop's Avatar
no the car didn't stall and strange thing is that normally in first gear the car will jump if the breaks are not applied. I will check my car again tonight after work. My car was in nuetral while the engine was on since I don't have turbo timer. I simply moved the shift knob into first without stalling the car
Old Feb 26, 2004 | 01:14 PM
xphillipjrx's Avatar
Clutch
Maybe you just got lucky. Keep trying that and you'll soon be in the market for a new clutch.
Old Feb 26, 2004 | 07:28 PM
im gonna try and just let off the clutch real slowly and see if the car stalls or not... how hot/cold is it where you live?
Old Feb 26, 2004 | 07:37 PM
SoR's Avatar
SoR
Re: Clutch
He'll be in a market for new tranny
Old Feb 26, 2004 | 07:51 PM
metaphysical's Avatar
Registered User
clutch? nope...try it. You won't be able to get it into first. You'll just get grinding and pull back.
Old Feb 26, 2004 | 10:15 PM
timzcat's Avatar
If this is true, start shopping for a clutch.
Old Feb 26, 2004 | 10:36 PM
superz's Avatar
yep. The ONLY way that first gear can engage without pressing the clutch is if the disc is worn down. The stock Evo clutch has small limiter studs on the pressure plate that will let the clutch disc spin free when it is worn beyond the limits.
Andrevo
50
Feb 22, 2013 10:40 PM
EViR
Apr 26, 2010 10:45 AM
steven121
Lancer Tranny/Drivetrain Tech
Nov 18, 2009 10:19 AM
Ph3n1x
Dec 23, 2005 11:26 AM
TrojanMan
Apr 6, 2005 09:52 AM
