Poor cold start, EDM 4G63
Old Oct 1, 2013 | 07:16 PM
Dvolution's Avatar
My IV has a USDM 260 ecu running an EDM Evo 8 engine. The engine started great the first try, even though it had 2 CEL's for the missing EGR. Once I disabled the EGR in the FAA and FCC periphery, the engine began to have trouble on cold starts.
The engine will maybe fire on 2 cylinders and then just continue cranking.
If I stop cranking exactly when it fires those couple times I can get it to start but it stumbles for 5-10 seconds until RPM raises to idle.
If I let it crank past those 2 little sparks, stop, and then continue cranking it starts perfect without turning 1 revolution; like it had compression, just didn't give fuel or spark.
To summarize: It starts fine but only if I turn the key twice.
Old Oct 2, 2013 | 11:17 AM
J_Striker's Avatar
Check to see what your fuel pressure is doing. If the pump isn't able to prime the system properly then it would take longer to start the veh.
Old Oct 6, 2013 | 10:43 AM
Dvolution's Avatar
How do I monitor the fuel pressure?
fostytou
359
Oct 23, 2025 09:54 AM
xceler8rob
34
Jul 17, 2016 12:57 PM
benny23
Jul 31, 2015 04:10 PM
Hotsauce101
May 14, 2015 09:50 PM
joel(PA)
23
Mar 25, 2011 10:26 AM
