evo engine failure - *video*
Old Oct 2, 2013 | 10:07 AM
stunt2's Avatar
short introduction: during time attack session car suddenly lost all power and began to smoke terribly. pulled over in pitlane, popped the hood and there was oil and smoke coming from vta catch tank (along with the smoke from exhaust). engine was obviously pushing oil in combustion chamber and sounded horribly
next day pulled rocker cover to see if there was any broken valve spring, retainer, valve stem seal or something. seems everything is on its place. removed plugs and there are puddles of oil in all cylinders. at least in three of them for sure. checked dipstick, no signs of water in oil.
no rough idle, AFR is good at idle, oil pressure is good...
would like to hear suggestions before I disassembly the engine. here is the vid of the sound
p.s. about engine - it's 2.3 with manley H beams, ACL race bearings, wiseco pistons (not HD,with upgraded pins) and S2 cams
Old Oct 2, 2013 | 01:44 PM
mxguy1286's Avatar
broken/melted piston
Old Oct 2, 2013 | 02:14 PM
stunt2's Avatar
all four ?
Old Oct 2, 2013 | 03:22 PM
ExViTermini's Avatar
Done a compression check yet?
Old Oct 2, 2013 | 04:24 PM
bbyevo8u's Avatar
almost sounds like its the clutch
Old Oct 2, 2013 | 04:51 PM
Joshthree6three's Avatar
That sounds terrible don't run that engine. You are going to need to inspect.
Old Oct 2, 2013 | 09:48 PM
stunt2's Avatar
no, haven't done the compression test yet
Old Oct 3, 2013 | 03:06 AM
bubba17's Avatar
melted pistons sounds like
Old Oct 3, 2013 | 09:54 AM
stunt2's Avatar
I think this explains the sound and oil in all cylinders
Old Oct 3, 2013 | 09:58 AM
stunt2's Avatar
question: what to do next apart from changing the turbo ?
hope the intercooler would catch the broken parts of the wheel ?
Old Oct 5, 2013 | 12:05 PM
Sircuit hero's Avatar
That happened to me but luckily my catch can caught most the metal shavings (integra).
I say clean out the intercooler and pipings
Old Oct 5, 2013 | 12:08 PM
Have you done a compression test yet? Did all cylinders hold the same psi? If so then maybe your engine is still good, change the turbo and burn off the rest of the oil in the cylinder, if the smoking stops then you're good if the compression test comes back good
onlynamenotused
15
Oct 13, 2018 11:48 AM
plan:b
Dec 25, 2015 09:07 AM
stunt2
May 27, 2014 11:19 AM
Ichigo0Soul
21
Mar 26, 2014 05:43 AM
Estorilblau
Lancer Troubleshooting
Mar 14, 2012 12:39 PM
