boost sputters under WOT
Old Oct 26, 2013 | 08:13 AM
  #31
1 evo8 1's Avatar
not really she spools up just fine.. its a stock turbo but just as soon as you go higher then 10 something psi it just breaks up
Old Oct 29, 2013 | 08:00 AM
  #32
1 evo8 1's Avatar
found out the hairline crack isint so hairline anymore.. puffs air out like non other.. going to try to weld fix it for now and change the throttle body shaft seals. also regapped plugs.
Old Oct 29, 2013 | 12:40 PM
  #33
1 evo8 1's Avatar
changed the shaft seals car is boosting like a champ!
Old May 8, 2020 | 02:14 AM
  #34
Riccardoevo4's Avatar
Originally Posted by 1 evo8 1
cant figure out what the problem is.. every time i boost it after like 10 psi a weird noise comes out the exhaust and i have major power loss..
i've tried it in every gear there all the same just sputters and goes no where.
put new plugs in gaped them to the right specs.. boost leak tested and just the throttle body seals are leaking. dont know if thats from it.
anyone else have a similar issue?
I have the same issue it spits and pops at around 10psi was told the fuel pump but about to replace it
papabeardoe
Jun 13, 2017 04:06 AM
ffsman12
11
Jan 15, 2015 08:31 AM
anjapower
22
Apr 27, 2013 04:21 AM
rEVoLed
12
Aug 25, 2012 12:12 PM
OG
Dec 15, 2011 03:48 PM
