Engine start help
Old Nov 2, 2013 | 07:43 PM
cardiacdog's Avatar
Engine start help
Hey guys need some help. 2006 evo full track car. When trying to start car, I don't get any engine turnover. Just starter turning over. Tried to jump thinking battery wasn't strong enough with no luck. Pull/roll start in 2nd gear and it fires immediately but even after letting it get hot, if I shut it off I can't refire without a push/pull start
Thanks for any advice
Sean
Old Nov 2, 2013 | 08:27 PM
barneyb's Avatar
If the starter motor is running then the gear on the starter is not engaging the flywheel. In other words, broken starter. Fix or replace.
Old Nov 4, 2013 | 11:32 AM
pinoyevo23's Avatar
The starters shot man. Had the same problem with myself. Replaced the starter and went on my way again
Old Nov 4, 2013 | 01:33 PM
hiboost2.0's Avatar
Yep if the starter is spinning but not engaging the flywheel, the solenoid on the starter motor is not doing it's job.
Old Nov 4, 2013 | 04:19 PM
OhioWhiteEvo8's Avatar
Yep I just replaced mine
Old Nov 5, 2013 | 04:26 AM
cardiacdog's Avatar
Thanks for the input. Off to the shop today
Old Nov 5, 2013 | 07:26 AM
If u have basic hand.tools do it yourself man pretty easy stuff
Old Nov 5, 2013 | 09:37 AM
barneyb's Avatar
Yeah, disconnect the battery, unbolt the exhaust in front and at the first hanger - two wires and two bolts on the starter if I remember it correctly.
Old Nov 5, 2013 | 11:30 AM
You said it, if u are replacing with an oem part you won't have to even disconnect the downpipe but the aftermarket ones are about inch longer and won't allow you to get the new one in if aftermarket
kmodo
Oct 8, 2016 12:51 AM
JHS VIII
May 14, 2012 05:19 AM
Creamo3
33
Oct 1, 2006 05:28 AM
jk_addict
Nov 30, 2005 11:57 AM
Hungbee112
Dec 22, 2004 10:10 PM
