Need some help with valve spring install
So after measuring all the valve springs, this is what I am looking at. All of my intake springs are within .010, except one on #4 which is .030 off.
Exhaust side, looks like 6 of the springs are .030 off.
Well, now I guess I have to wait for the high rev springs to get here tomorrow. Is it safe for me to assume the new springs will come in about the same measurements being .030 off on the exhaust side? Or can the new springs make things better or worse?
AS for feeling it, anytime I revved the car out to its redline, the car would fall on its face, and then continue to run with a bad hesitation feel for a few seconds, then just magically go away. All would be good, until I would try and rev it out again.
My numbers might be a little skewed too. The caliper that I am using, I am using the metric side, then transferring millimeters to inches by dividing by 25.4. 1mm difference in the measurements is around .030 inches. So a mm really throws the number off.
I know now where an actual spring height tool would be great, but I dont have the resources to get one or make one.
Im happy that I didnt have any numbers just way off, out of a shim range lol.
Thanks a lot man. I was waiting for you to post up, as ive seen you post in so many threads on here and dsmtuners about head work lol.
I get the springs tomorrow. I have a digital caliper that I was hoping would work, but it might be too big to get in there and measure correctly. The only shims ive seen for sale are from some vendors that sell Tomei shims, they come in packs of 8, and in only three increments, .2mm, .3mm. and .5mm.
I did not see any shims from the machine shop. I really wouldnt expect them to shim them as its just a local machine shop, they do good work, but mainly specialize in big motor apps. Even if they did shim them, I would imagine they would be incorrect, as they would have looked up the specs for stock evo 9 springs and I have the gsc beehives in there now.
I get the tool from the eurotools tonight, so I am gonna pull the springs out, maybe then I will see some shims, maybe not lol.
You should be able to see a shim, but most "Local" shops do not stock the import small ones.
Now from what I have seen, and measured. On the 1g and 2g DSM heads, what the FSM says, and what I have found are 2 totally different spring installed specs.
It looks like that GSC has used real world numbers, and not the engineering specs from the FSM.
So my question is are shims necessary if you are just replacing the springs and cams cuz all the threads I've read didn't mention anything about shims. I'm not a big fan of doing the same job multiple times so I would rather have all the information before I begin the job. I currently have supertech single springs and was looking at upgrading to map's ultimate duty beehives with titanium retainers when I replace the cams with kelford 272s.
It is not all hand checked and assembled like you get from a decent machine shop.
Good choice on springs for the Kelford 272 cams.
They have the thought process of "It ran before, It will run again" This thought process leaves a lot on the table and costs you HP and money.
This thread will make that point clear.
https://www.evolutionm.net/forums/ev...tion-10-a.html
https://www.evolutionm.net/forums/ev...e-springs.html
Not sure if this will help but this is what lunati outlines as the procedure for their springs and they are a quality name in sbc applications.
http://www.lunatipower.com/Tech/Valv...pringTech.aspx
The only part that really does not apply is the section on rocker arm to retainer clearance.
What you have to be aware of instead is follower to valve lock/retainer clearance. But that has to do with the valve tip above the retainer, and how much the valve tip has been ground down.
What are the actual measurements you took?
Now what I want to know is why, those valves are so much more than the others. .030 is a good amount.
Were the seats cut that much deeper?
Did they correct the valve tip height?
Were the valves unshrouded on those seats?
1mm=.03937 (.040)
So 1mm is closer to .040 than .030
I multiply instead of divide when I have to convert from metric to SAE
I have had to add as much as .120 worth of shims on some applications to get the springs to be correct.
The Tomi shims you spoke of earlier wold work out to be
.2mm x .03937 = .007874
.3mm x .03937 = .011811
.5mm x .03937 = .019685
The shims I use are
.015 x 25.4 = 0.381mm
.030 x 25.4 = 0.762mm
.060 x 25.4 = 1.524mm
From what I am picking up from reading this thread, is your willing to do the wrench time and go to the expense of getting it right.
I would suggest you find a shop that understands your head and has a solid understanding of how to set up springs and have them do it. The right shop will have the right tools and equipment and parts in stock.
I can understand the DIY attitude, and wanting to learn. Nothing at all wrong with that.
I also understand it it would be more wrench time to R&R the head, and more expense in gaskets and shop labor.
But trying to do this balancing act with makeshift tooling may cost you more in the long run.
If the head is in good shape, a spring install, with a handful of shims, and maybe some new (vition blue) seals, should be around $100 and take an hour or so.
Thank you bogusevo for taking the time to address what are probably dumb questions. I will def make sure to check specs when I'm doing the head. And I would love to be able to take the car to a professional shop but unfortunately I don't trust a single shop up here there's maybe 6 or 7 evos in all of alaska and the shops would rather race um than work on um. And one more dumb question where can I order these shims from?
I am gonna pick up a digital caliper today. I am gonna try a different way of measuring the springs. I am gonna measure the thickness of the stock seats, then the thickness of the new titanium retainters. Then I can actually use the digital caliper and just measure from the very bottom where the seat contacts the head, to the top of the retainer. Then just subtract the retainer and seat thickness. I read on another forum this is how a lot of guys do it in the garage that dont have the exact tools the machine shop does.
I will take some meaurements tonight when I get the new springs in.
I am the same way, the local machine shop around here, I hate to take my stuff to them. ive heard they do good work with the domestics, but i feel like sometimes they just throw stuff together and get paid.
I can understand how you both are sketchy on shops. I have just wored through a pile of heads that were horrid done.
"just get paid " builds, the head inspection 10 is one
Another was ported so poorly, you could feel every snail trail, and burr mark.
here is a true horror story, guy had the head built, and bought new Ferrea +1mm valves, we all know thats about $400 on the valves.
Apparently the the shop did not have the equipment, or did not want to cut the seats for +1mm valves. so they ground down the valve heads back to std dia !
Thats what I am talking about lol. Some of the shops I feel just have old school techniques still. Which work great for some applications but on newer stuff, might not cut it.
Ill tell ya, I feel better about the way that I measured tonight. With measuring the thickness of the spring seats and retainers, and then using a digital caliper and measuring from the bottom to the top of the spring retainer, then subtracting the seat and retainer.
My springs fell in the 1.55-1.56 range. Gsc recommends a 1.55 on their website. Travis from GSC told me to do 1.56 on the intake and 1.54 on the exhaust, so it sounds like .010 either way is tolerable. So I felt comfortable enough to put the cams back in.
Im gonna finish it up this morning and fire it up.
marksae
91
Apr 23, 2018 07:48 AM
Exsubie22
24
Dec 29, 2016 10:01 AM
BR350VIII004
Apr 21, 2016 08:43 AM
tscompusa
Oct 21, 2015 02:47 PM
