Air bubbles from Clutch master to Brake master?
Old Nov 7, 2013 | 01:31 PM
hiboost2.0's Avatar
I just replaced my clutch master cylinder due to it leaking through the firewall. While I was in there I replaced the clutch line too.
Now when I go to bleed it after I push the clutch pedal to do the bleeding process, multiple air bubble come from the clutch master cylinder and go into the brake master from the tube that connects the two.
The clutch pedal has not been adjusted yet, could it be from the clutch pedal being adjust too far out and not allowing fluid back into the brake master?
Thank you to anyone who contributes.
Old Nov 8, 2013 | 10:28 AM
hiboost2.0's Avatar
Anyone? I've been trying to bleed it and went through 64oz of brake fluid and I'm till getting TONS of bubbles. I'm at a loss.
Old Nov 8, 2013 | 10:36 AM
snafufx's Avatar
Are you filling the brake fluid all the way too the rim when you bleed it? Besides that, sorry I got nothing. Besides pushing clutch down, open valve, close, lift clutch, rinse repeat it should get all the bubbles out. In the container the slave cylinder valve lets the fluid out, I'll fill it up about 1/4 of fresh fluid just in case to prevent any more air from coming in. Good luck
Old Nov 8, 2013 | 01:56 PM
hiboost2.0's Avatar
All good brotha I figured it out, thanks for the reply!
Old Mar 20, 2016 | 07:02 AM
7rrivera7's Avatar
If you figured it out, and this might happen to another member, why don't you explain what you did?
Old Mar 21, 2016 | 01:49 PM
BiFfMaN's Avatar
Over fill the Brake fluid reservoir, if you don't you will get air.
Step 2 in these instructions. is what he was missing.
https://www.evomoto.com/tech_article..._article_id=17
Old Mar 21, 2016 | 02:48 PM
7rrivera7's Avatar
Thank you.
Old Mar 23, 2016 | 05:38 PM
1UpMoto's Avatar
reverse bleed it, will get all the bubbles out the first try....definitely the easiest way.
kyoo
Jan 25, 2020 04:37 AM
maxroach
Oct 23, 2017 11:21 AM
Drift4
26
Sep 2, 2016 11:31 PM
NewEvolutionIX
13
Aug 26, 2016 04:41 PM
vipevo9
Aug 25, 2016 12:36 PM
