CEL with new turbo
Old Mar 1, 2004 | 10:46 PM
memo3's Avatar
Originally posted by propellerhead
See the diagram below. The hoses to and from the solenoid valve can be removed and plugged. In my case the pressure tap coming off of the turbo compressor is plugged and instead my MBC is fed from the manifold tap leading to the bypass valve. My wastegate actuator is fed by the MBC.
that pic helps a lot.. thanks
Old Mar 2, 2004 | 08:54 AM
stevEVO8's Avatar
No all that needs to be done is leave the sylenoid plugged in. I did this on my Eclipse and never got the CEL.
This is the way its been done on mitsus for a long time. Just leave them hanging, plug them, remove them, Just leave the sylenoid plugged in.
Old Mar 2, 2004 | 09:44 AM
memo3's Avatar
Great! thanks for the help
I tried that last night the selenoid got very hot.. selenoid itself without the hoses.. is it suppose?
Old Mar 2, 2004 | 10:18 AM
stevEVO8's Avatar
How hot are we talking about? is it from engine heat?
I never checked whether mine did or not. I jsut unplugged the hoses and let them hang and never thought about it again.
Old Mar 2, 2004 | 09:40 PM
memo3's Avatar
For how long have u been using like that?
This is how hot it was,
The engine cooled down for about couple hours and then put the selenoid back.. and in about 5 min (no driving) it got pretty hot when i touched it... it was nearly touchable
I am not sure how hot it gets with the hoses working... that might be normal but just wanted to make sure everything is right..
Old Mar 3, 2004 | 08:45 AM
stevEVO8's Avatar
I did that for about 2 years on my DSM.
I have never heard of that happening. You may want to try unplugging it and doing the resistor trick the others were talking about.
Old Mar 3, 2004 | 09:10 AM
propellerhead's Avatar
I'm pretty sure the boost solenoid is "normally open" when no power is applied. This would prevent an overboost situation if the solenoid failed. Remember, the boost solenoid vents boost pressure being fed to the wastegate actuator. I'm thinking that if the boost is at or below normal levels the coil will be energized and would get hot over the course of normal operation. Then again, I could be completely wrong...
Regardless, a coil (or resistor) with 30 ohms of resistance will draw .39 amps of juice at 13 volts. This translates to 5 watts of heat energy that is put out. The coil will get hot if it is continuously energized.
Old Mar 3, 2004 | 05:35 PM
memo3's Avatar
hmm thanks for the info
so that sounds like it is normal for selenoid to get hot...
sofly1990
16
Oct 21, 2013 08:16 AM
ravnos04
Cobb AccessPORT
Feb 21, 2012 12:24 PM
karolis.bou
24
Dec 31, 2010 07:52 AM
FnF EVO8
Sep 23, 2010 12:19 AM
08_XXX
Oct 5, 2008 04:11 PM
