Doing clutch on my 05 SSL - Trans. Filter?
Old Nov 11, 2013 | 09:29 AM
YAMAHArYder's Avatar
Hey doods -
So going through 'the' clutch install writeup, he mentions something about replacing a walbro filter in the transmission?
"14. Digging in to the Walbro install kit, grab the new pump filter and the small retaining ring and install the filter onto the Walbro pump. Set the filter in place and push the retaining ring on as best as you can (just so the ring doesn't fall off). Place a 5.5mm or equivalent socket over the retaining ring and gently tap it on until it sits flat against the filter housing."
For some reason i cant find any other info on this...
There's a filter for the oil in the transmission?
Can anyone shed some light?
Old Nov 11, 2013 | 10:04 AM
wang4u's Avatar
There is a trans oil filter. Heres a how to: http://www.evoxforums.com/forums/showthread.php?t=35444. Afaik walbro only makes Air and Fuel filters.
Good luck
Old Nov 11, 2013 | 10:05 AM
meckert's Avatar
There is no pump in a std trans. So there is no filter or any place to put a filter as there is no circulation other than sloshing of the gears to lube the trans. Either you mis-read it or your info is beyond incorrect. You are talking about the '05 ssl right and not a X? Good Luck.
Old Nov 11, 2013 | 10:27 AM
wang4u's Avatar
Oh duh lol I was thinking it said SST. Yes there is no pump or filter on the 1-9s. Just the X. And I just did a search for the step 14, its talking about a 255lph fuel pump.
Old May 28, 2015 | 04:28 PM
Ghost159's Avatar
were you able to figure out what this step was talking about? is it saying to change the fuel pump?
xXANCHORMONXx
Apr 5, 2024 01:01 PM
Laurie Mangum
May 30, 2017 07:47 PM
dawidevo
For Sale - Cars For Sale
Sep 17, 2016 10:03 AM
ProPilot04
Aug 29, 2011 02:29 PM
sabastian458
Dec 11, 2008 12:31 PM
