Getting rid of engine idle noise
Old Nov 15, 2013 | 02:48 PM
silverevo05's Avatar
I have been reading the sticky above about ridding the IX of the belt noise.
Apparently the bracket is the issue per post #586
Old one VS New one
Below is from the thread
Ok....here is the deal. Just picked up the car. The dealer tech said that ALL Evo 9's have an issue with the timing belt rubbing against the crankshaft position blade wheel. Here are the new parts they installed on mine to remedy the issue:
Part Number MR984375 Adjuster, Timing Belt Tension Qty 1
Part Number MD369999 Pulley, Timing Belt Tension Qty 1
Part Number 1091A133 Bracket Cylinder Block Qty 1 *****Updated New Part from Mitsu that supposedly fixes the noise problem. Original bracket was machined incorrectly by supplier to Mitsu*****
Part Number 1145A038 Belt, Valve Timing Qty 1
Part Number MR984778 Belt, Balancer Timing Qty 1
Mitsubishi Techline Case #140114
Service Description: Removed and replaced Timing Belt Adjuster, Tensioner Pulley, and Bracket as per Techline. Replaced Timing Belt and Balance Belt while Tensioner Bracket was replaced under warranty.
They also replaced the crankshaft sensor blade on the car but left it off the reprinted repair bill they gave me. Oh well. Total cost for me was $159.76 for the Tming Belt and the Balance Belt that I had them put in new as opposed to the old ones.
You can have the tech at your dealer call the techline and look at my techline case number to see all the part numbers for your repair if needed.
I'll let you guys know if I hear the noise anymore over the coming weeks!
I wanted to do this with my 60k service (ALL THREE BELTS & Bracket) though I wanted to know what is involved to change out the bracket and is it necessary to change ALL THE PARTS this guy above said (if so how much time would this add)
Old Nov 15, 2013 | 03:16 PM
vmrevo9's Avatar
Veteran: Air Force
Thanks for posting!
Old Nov 15, 2013 | 03:38 PM
meckert's Avatar
Interesting---so is this the same for VIII's as well. I know its posted for a IX--just wondering as I would replace it when I was in there is I had too.
Old Nov 15, 2013 | 03:44 PM
^ No only an issue with the 9 Mivec.
I just want to know from people that have done this as to how mush is involved in changing the bracket out and anything I should look out for
Thanks
bpdean
19
Dec 29, 2015 03:08 PM
alexc
Jun 16, 2015 11:20 AM
anthonypazsd
Jan 31, 2010 03:01 AM
