'Spark blowout', Fouled plugs?
Old Dec 15, 2013 | 08:12 PM
  #31
Ted B's Avatar
Originally Posted by Ghostdriver22
If Im no running e85 should I have to run a gap smaller than .025? I just got new BPR7ES's and I am still getting a miisfire at 12afrs while going into boost, cruise is smooth, no problems and 15afrs
I wouldn't assume the plugs to be the issue. That isn't an area that places particularly high demand on the ignition system. You can try swapping your factory ignition just to rule out a coil problem, but what you're experiencing can be caused by a variety of things, such as tuning, pressure leaks, etc.
Old Dec 29, 2013 | 03:11 PM
  #32
ch53avitech's Avatar
Originally Posted by Ted B
The 0.026 should be ok ... when you switch to BPR7ES. When you do, any stumbling and misfires (both part and WOT) will instantly disappear.
My problem is back. Back to the plugs. BR7ES or BPR7ES?
Old Dec 29, 2013 | 03:13 PM
  #33
Ted B's Avatar
BPR7ES is correct.
Old Dec 29, 2013 | 03:39 PM
  #34
Thanks Ted.
Old Dec 30, 2013 | 07:50 AM
  #35
Ghostdriver22's Avatar
Originally Posted by ch53avitech
Thanks Ted.
Problem solved! Switched back to factory coils just like you said. Issue was the aftermarket coil over plug setup had fouled because of excessive moisture. Im sayen ever denso coil spring that comes in contact with the top of my plugs was BLACK and covered so bad I dont know how it even ran. Thanks for help Ted B
Old Dec 31, 2013 | 10:48 PM
  #36
I'm happy to say it Ted. I was skeptical but you were right. Only problem is the O'Reilly store I buy parts from doesn't normally stock the BPR7ES but they do have the non-protruding plug version. How would those fair? They said they have to order the R's directly from the manufacturer and they took 3 days to arrive.
Old Dec 31, 2013 | 11:19 PM
  #37
Ted B's Avatar
Nope, you want the protuded tip plug (BPR7ES). Do not get anything else. Go to the closest Advance Auto to you. They stock it. Just ask for NGK part no. 5534. That's all the info they need. You'll be in and out of there in <5 min.
jrmav32
Jul 3, 2017 11:44 AM
Jared Murphy
11
May 15, 2017 08:45 PM
Ekoy
AEM EMS
27
Mar 29, 2017 10:21 AM
BiHBeast
Sep 29, 2012 11:50 PM
taylorgang
Oct 3, 2011 06:21 PM
