No g force pull feel !!!
Old Nov 22, 2013 | 12:11 PM
JDM.Spec's Avatar
My car is a ix MR, with a milage below 10000km, just after buying it i realized that it is not pushing as hard as it should. I had problem with the clutch and upgraded it to exedy Stage 1 HD with flywheel, but still the problem is not solved, the car is fast but there is no 'G' force feel,i checked the boost and plugs but everything is fine.... years back i took a ride in my friends ix GSR and that had strong 'G"
feel and the car was stock, and compared to that my one seems to be riding rpm and no climbing in power......
HELP PLEASE!!!!
Thanks In Advance.
Old Nov 22, 2013 | 12:18 PM
detroit pistins's Avatar
Is yours stock? Have you done a boost leak test?
Old Nov 22, 2013 | 12:25 PM
Ev0ikon's Avatar
It's normal. You butt just got used to the pull.
Old Nov 22, 2013 | 01:40 PM
thepoint4life23's Avatar
agree. hints why people keep modding cars
Old Nov 22, 2013 | 01:56 PM
STOCK03EVO8's Avatar
YEP
Definetly just used to the feeling of the car...
Time to do a boost controller, tune, turbo back...
sitting in a seat with a turbo car will still feel different than you driving one....
If everything tests fine, no boost leaks it really is simply you are used to it.
Best Regards,
steve
Old Nov 23, 2013 | 06:47 AM
JDM.Spec's Avatar
Yes, the car is totally stock except the ralliart drop in intake....
i've tried replacing the cat with a test pipe and the whole exhaust is stock.... the car became faster but still no G feel.... and yes done with the boost leak test, boost is perfectly fine....
Old Nov 23, 2013 | 09:18 AM
adriano_917's Avatar
This is your problem right here Yes, the car is totally stock.
Old Nov 23, 2013 | 09:20 AM
Assuming you are boosting stock boost levels which would be around 14.7 psi if Im not mistaken, how much psi did you put into the system when doing a boost leak test ? I had the same problem only testing the system to 20psi when Im pushing 30psi and it would not leak at 20psi but at 30psi it would leak all over the place.
ohhgyeahfasho
Mar 6, 2014 04:46 PM
JDM.Spec
Nov 24, 2013 10:18 AM
babaz7
10
Jun 29, 2012 08:18 PM
speedfreak24
Northeast Region
12
Aug 17, 2011 01:04 AM
jcdeng
Apr 25, 2010 06:29 PM
