Clutch disk size 4 vs. 8
Old Nov 24, 2013 | 01:41 PM
TonyPajamaz's Avatar
My clutch showed the first signs of slipping the last 2 nights so I've started my research and have been looking for and reading as much information as I can.
I know it's been covered a few times both on here and lancerregister that you can use the evo 7,8,9 pressure plate and clutch as long as you use the respective flywheel.
Most forum responses just state that the 7,8,9 disk is bigger, but there is one post here on evom that states the 4 disk is 240mm and the 8 disk is 280mm.
However, I've been looking through multiple companies pages as well as ebay pages and I've noticed that clutch kits that are evo 4,5,6 specific come with a disk that is 240mm in diameter. The odd part and the reason for this post is that all of the clutch kits that are evo 7,8,9 specific also say the clutch disk is 240mm in diameter.
Unless i'm missing something and the 4,5,6 disk is not actually 240mm, logically a 7,8,9 disk should work fine.
I'm located in Canada and am looking to replace my stock kit with an Exedy Stage 1 kit. It's easier to get the "stage 1" kit from Exedy for an evo 8 in North America.
Thanks in advance for any help/clarification!
Old Nov 24, 2013 | 03:53 PM
wang4u's Avatar
I dont know the exact size difference, but there is a slight difference. The 7/8/9 clutch is bigger, as is the flywheel. To use a 7/8/9 clutch in a 4/5/6 you need the flywheel as well from a 7/8/9.
Old Nov 24, 2013 | 06:05 PM
Well I believe I answered my own question. The problem is, I was looking for sizes going off of this link:
https://www.evolutionm.net/forums/ev...placement.html
The user must have been pulling numbers out of you know where.
After looking on Exedy Europe's website, it's pretty clear that the Evo 4 has a disk size of 230mm and the evo 8 has a disk size of 240. This makes more sense:
http://ww3.elcome.co.uk/Exedy/Default.asp?i=30
The confusion was also being fueled by false information on websites and ebay pages. There are quite a few vendors that are advertising 240mm disks as evo 4,5,6 disks. Some of them include the appropriate flywheel. Yes, with the appropriate flywheel that clutch would fit the evo 4,5,6 but you would still have to shave down the dowel. The ones without flywheels included would definitely not fit.
Technically speaking, anything with a 240mm disk is not an evo 4,5,6 clutch even though they are being advertised as so.
Old Nov 25, 2013 | 12:45 AM
wang4u's Avatar
Haha I posted on that first thread. But ya, for the most part, many of the US vendors have no clue about the older Evos. Got to be careful what you read on US Ebay. Glad you found your answer. My next suggestion was going to be contact the JDM or EDM vendor to be absolutely sure. Ive been sending a lot of my questions to Camskill in the UK. They know everything about the 4/5/6 platform. Though I never inquired about the clutch disc size, as I knew from other threads I read, that the later Evo clutch will fit with the flywheel, and dowel modification.
So pick up any Evo 8 clutch and to save a few bucks, pick up a used OEM Evo 8 flywheel. Resurfacing is inexpensive, and will get you back on the road cheaper.
Old Nov 25, 2013 | 06:49 AM
One of the vendors on U.S. Ebay does provide the oem replacement for the 4/5/6 which is 230mm. I'm not looking to make the car any more powerful than it already is with an intake and open exhaust.
The clutch will be about 290 shipped to Canada and I'll just get my oem flywheel resurfaced!
Old Nov 25, 2013 | 09:33 PM
A gentleman I know is parting out an evo 4 right now, he was able to confirm for me today that the oem 4 disk is 230mm.
mick9ornothing
Apr 4, 2017 11:21 PM
real fast
16
Nov 21, 2016 09:49 AM
Vivid Racing
Evo 'For Sale' Engine Internals and Drivetrain
Mar 18, 2015 11:18 AM
4g63evoeight
Jul 16, 2014 10:31 AM
Nomad4g63
Apr 14, 2009 08:34 PM
