L19s... Do you re torque after heat cycle?
Old Dec 2, 2013 | 12:48 AM
itsmrrizz2you's Avatar
I think I might of lifted my head. I have 2k miles on a new build with brand new arp l19s. I ran car 3 different times on 34+ psi and the last time lifteing the head I'm pretty sure. Do these head studs require being re torqued after track runs or a lot if boost after install???
Old Dec 2, 2013 | 01:24 AM
ch53avitech's Avatar
I didn't re-torque mine. Mine are torqued to 105 ft/lbs. I'm also aiming for high 40 psi in the future.
Old Dec 2, 2013 | 01:40 AM
Furthermore, I feel that re-torquing headstuds ruins the seal that is already on the head gasket.
Old Dec 2, 2013 | 05:17 AM
I heard now from a few ppl that they should be re-torqued after a lot of boost and a break in heat cycle. im going to call arp direct today and see what they have to say
Old Dec 2, 2013 | 05:22 AM
Robertv34's Avatar
Hmmm let me know what they say
Old Dec 2, 2013 | 05:33 AM
240Z TwinTurbo's Avatar
I retorqued the MAP H11 headstuds after a few days of running. Let the car cool overnight and using the OEM torque sequence I backed off the nut ~1/4 turn and then retorqued before moving to the next in sequence. I did notice a few nuts accepted more movement to reach full torque.
Old Dec 2, 2013 | 06:49 AM
Ev0ikon's Avatar
Agree.
Old Dec 2, 2013 | 11:19 AM
evolve_VIII's Avatar
I did my l19s after a drive and heat cycle. Torqued to 105. I did notice that there was a difference in a few of the nuts. Let it cool to room temperature.
Old Dec 2, 2013 | 02:46 PM
way2qik's Avatar
Always re-torque them. Especially if you are running 35lbs+ of boost.
Old Dec 2, 2013 | 02:48 PM
WRC-LVR's Avatar
This /\/\
Old Dec 2, 2013 | 04:12 PM
michaelrc51's Avatar
I torqued mine to 115 as Buschur recommended. I checked them after a bit of driving and heat cycles and non of them moved at all.
Can never hurt to check.
Old Dec 2, 2013 | 09:46 PM
Some do, some don't really. If you'd like that reassurance then by all means, it definitely wouldn't hurt. I didn't re-torque mine and I'm doing fine. To each their own.
Old Dec 2, 2013 | 09:56 PM
Paul Walkin's Avatar
I don't agree that you must loosen and retorque them, but definitely check them...
Old Dec 2, 2013 | 10:29 PM
Thanks for all the info guys I really appreciate it. I will call arp directly in the morning as I didn't get around to it today. I will let you guys know what they say
Old Dec 2, 2013 | 10:31 PM
Btw I was running 37 psi fp black
