Pistones on jun stroker kit cracked can I use weiseco hd1400 piston
Since its june im wondering if I can use other piston. The Jun piston are 1500.00 usd way too much $$$
also is the jun stroker kit long rod?
Three things to check to see if other pistons will work.
1) Piston dia.
2) wrist pin dia.
3) compression height of the Jun piston.
If you know what the crank stroke is, that can be helpful.
Also if you know, or measure the C2C length of the rod.
1) Piston dia.
2) wrist pin dia.
Strm Trpr
16
Aug 10, 2009 07:32 AM
Gump
May 15, 2009 09:02 PM
rawandbruteEVO
31
Feb 2, 2007 07:25 PM
