Another "what turbo to go with" thread
Looking to be in the 500 to 600whp on e85
Built 2.0 long rod
Gsc s2 with valvetrain goodies
Custom 3" ICP with 3" IC
ToxicFab FF t4 with dual 38mm wg
Custom 3" downpipe
Custom 3" aluminum catback
ID 1000s
Twin Wallys or single 400
Exedy Twin
Grimmspeed ebc
Im leaning more on a pte 6266 but I want some input from the community about boost lag / spool
Some drag, autox, weekend warrior kind of fun
Any input please share
Thanks in advance
Built 2.0 long rod
Custom 3" downpipe
ID 1000s
Exedy Twin
Grimmspeed ebc
Thanks in advance
I have a 6265 and i made 500 on pump at 28PSI running out of fuel
. the 6266 will get you there no problem. ill be looking for close to 550 on pump when i get my car back together and the upgraded injectors with more boost.
you will need larger injectors though. My 1000's were running out around the 500hp range and caused me to have to drop the boost down a little bit. i ended up getting a set of 1200's. On E85 you may want to consider at least 1200+ size injectors
I have a 2.4 so that turbo doesnt have much lag, id think it would be a bit laggier and would make autox not as much fun. but dragracing your good to go.
evo8lento
Oct 18, 2016 09:22 AM
evoxsi
15
Sep 15, 2012 06:11 AM
