oil in compressor housing fp black dbb
Old Jan 20, 2014 | 08:29 AM
cfdfireman1's Avatar
M8NSTER = reading comprehension fail.
michaelrc51 it looks like they make a few, which STM tuned catch can do you have?
Old Jan 20, 2014 | 08:40 AM
M8NSTER's Avatar
^Try trolling somewhere else, dumba$$.
First off, I know for a fact that can happen. Second, I'm only trying to help out.
Take your trolling bi tch a$$ out of here if you have nothing worth saying!
Old Jan 20, 2014 | 08:47 AM
OK let's try that again.
Originally Posted by michaelrc51
2 lines from valve cover, 1 from vented dipstick tube, and 1 from vent for balance shaft inspection hole.
I talked to FP and they swore that this happening at idle was because there wasn't any line going from a vent to the air intake to create "vacuum" and pull air out of the motor. I just don't see how adding that line will create enough air movement to help, maybe I could see it on a sealed system but not a VTA with 4, -6AN lines.....
I bought everything to make the 2 lines to the valve cover -10AN but I am leaning towards just adding the line from the VC to the air intake first.
Old Jan 20, 2014 | 08:58 AM
M8NSTER's Avatar
Yes, cfdfireman1, lets read that again...
It says, "line going from a vent to the AIR INTAKE". It says nothing about a breather!
Breathers will vent out to the air (all STM cans I've seen have breathers). That can get sucked into the intake.
Again, I'm only trying to help. If I'm wrong who F'ing cares. Stop being a troll.
Old Jan 20, 2014 | 01:00 PM
mberenis's Avatar
Talked to fp and they said it only takes one to two psi to move oil past the gas rings. They said to run a pcv and then drill an additional port in the vc, run those two ports to the catch can, then run the can to the inlet and to not vta.
Im going to try running a line to the inlet bc ****s already soaked in oil what does it matter. I really dont want to run the pcv and drill another hole in my vc
Old Jan 20, 2014 | 01:49 PM
michaelrc51's Avatar
Mine is the 4 port firewall VTA one. I already stated it is VTA.
Yes, FP told me the same thing. Tell me how 4, - 6AN lines are even going to let .5 psi accumulate?
I will probably end up putting the line from the air intake to the valve cover just to see, even though it is VTA and shouldn't help......
Old Jan 20, 2014 | 02:21 PM
todd6027's Avatar
had a similar prob with a better brand bb turbo , oil pressure was too high , oil restrictor fitted to feed , end of problem . forgot to say im feeding it from the cyl head .bb turbos require less oil pressure as you dont need to float the shaft like jb turbos
Old Jan 20, 2014 | 05:50 PM
michaelrc51,
Question, did you install the filter with the .8mm (.030") restrictor from FP?
Please clarify for me and M8NSTER do you have any vent hose going to your intake pre-turbo with your current setup?
Old Jan 20, 2014 | 05:54 PM
Originally Posted by cfdfireman1
michaelrc51,
Question, did you install the filter with the .8mm (.030") restrictor from FP? Please clarify do you have any vent hose going to your intake pre-turbo with your current setup?
Yes, the restrictor is installed and no, there isn't a vent hose going to the intake pipe right now. But, I will most likely install a -6AN vent from the valve cover to the intake pipe and see if it helps....even though I don't see how it would....
This is the catch can I have
http://www.streettunedmotorsports.co...l_catchcan.htm
Old Jan 20, 2014 | 08:34 PM
mberenis's Avatar
Is this minimal amount of seepage past the gas rings going to actually hurt anything? Is it going to blow the turbo eventually or can i just leave it as is and forget about it... Few of you have said you have the same thing, just curious how many miles youve ran it like that and if you are still on the same turbo.
Thanks for the help and input!
Old Jan 20, 2014 | 11:38 PM
joseph143's Avatar
i refer you back to my first post on page one... I seriously doubt a turbo has ever been blown from an issue like this... but it will suck into your intake and cause detonation... which blows motors... i'm sure you aren't using a bb black in suck down 15psi... you are closer to 30... at 30psi the dynamic compression of a normal cylinder jumps to near 27:1... i highly suggest you vent the motor as best as possible...
like i said, hesitation, stumbling are big issues... plug fouling, misfire, detonation are more serious... and lowering the octane rating of your fuel is the biggest....
at idle pressures may be low but under boost your crank case pressure sky rocket if not kept in check.... check you PCV check valve to ensure its working... and make sure your breather setup is connected preturbo so it can vent under boost.
Old Jan 22, 2014 | 11:01 AM
lopillo_evo's Avatar
Veteran: Army
you guys running dbb, are you feeding the oil through the head or from using it from the bottom of the block? I have an FP Red DBB and I have the same issue I'm running a catch can VTA from STM and is setup like so, back of vc and balance shaft inspection breahter, and I have one line going to the intake and still getting oil. The guy above jospeh143 is my mechanic so I'll see him today and see what he has on mind to do it better.
Old Jan 23, 2014 | 05:32 AM
mberenis's Avatar
Im running it exactly how fp says, from the oil filter housing with the inline filter kit. Using their lines too.
Imo, i think this sucks and im kind of pissed i paid so much money for a turbo with weak gas rings. No joke i had an ebay 20g on my wrx and never had this issue. Why would an fp, name brand uber expensive turbo do this but a cheap pos ebay knockoff turbo made in china not? Not hating just upset and looking for answers.
In the meantime im going to run my catch can exactly how they say even though i dont see how its making 1-2 psi, enough they say to push oil past rings, is possible being that i have a huge 2" breather port. It just doesnt make sense. Smh maybe im just stupid lol
If anyone with knowledge can fill the gap of retard in my brain that fails to understand this theory of building pressure when theres an open hole in the system, please fill me in. Thank you
Old Jan 23, 2014 | 06:32 AM
Lol, same here.
People have told me it is normal but I still don't care for it and would like to alleviate this if possible.
Old Jan 23, 2014 | 07:50 AM
There is an alternative that's been used in racing applications for years.
