oil in compressor housing fp black dbb
Old Jun 8, 2016 | 06:29 PM
  #121
EvoIIIAj's Avatar
What does it mean if a brand new MHI DBB Red (Bought in early 2014) leaked oil into the compressor housing from the very first start up at idle? Before even being driven mine has done this.
I can take off the intake pipe and watch it push tiny amounts of oil into the compressor housing. I have a -10an on the side of the valve cover but it's currently not hooked up. Like I said, this is happening at idle from when the turbo was brand new.
Old Jun 8, 2016 | 06:50 PM
  #122
LetsGetThisDone's Avatar
Crank case pressure. Especially on cold start. You need that 10an line hooked up to the intake. And you need make the PCV bigger. Read the sticky in this section...
Old Jun 8, 2016 | 06:59 PM
  #123
EvoIIIAj's Avatar
Ok thanks. I'm getting the bigger fitting welded to my intake tomorrow to hook up the line. I also plan to do the STM sealed catch can which will increase the size of the PCV side.
Old Jun 9, 2016 | 05:20 AM
  #124
evolusean's Avatar
Haha yea rite! Good luck with that i bet it still does it after you install a -10 to intake.
Old Jun 9, 2016 | 06:05 AM
  #125
evolusean's Avatar
I mean sure try what letsgetthisdone says BUT that did nothing for many of us! Seriously good luck...
Old Jun 10, 2016 | 08:08 AM
  #126
EvoIIIAj's Avatar
I doubt just connecting the hose to the intake will solve it too, but after I get the STM Sealed can along with the -10an fitting on the side of my valve cover I will be very upset if it still persists..
Old Jun 10, 2016 | 08:11 AM
  #127
Mine works fine with a similar setup to the STM. I get very minimal oil in the charges pipes. Less than my stock turbo anyways, so for me its fine..
Old Jun 10, 2016 | 09:25 PM
  #128
JRally's Avatar
Welcome to FP DBB life.
If you want to help alleviate it as much as possible, run both valve cover ports and the balance shaft inspection fitting from stm to a SEALED AND BAFFLED catch can and then give the catch can a vacuum source such as the intake pipe or a vacuum pump.
Mauricio Evo IV
11
Oct 31, 2017 12:10 AM
romogst
Aug 25, 2017 08:07 AM
Evo__Lee
Sep 18, 2016 09:39 PM
Rmr298
Aug 24, 2016 03:31 PM
rajal13
Jun 17, 2016 08:39 AM
