How much someone would pay for built long block?
Old Feb 5, 2014 | 05:49 AM
Lexus01IS's Avatar
How much someone would pay for drop in long block. It would come fully assembled with every sensor from valve cover to oil pan. Engine is sitting on engien stand. I am thinking about selling the evo but wouldnt sell it unless I sold the engine 1st.
JAM 4G64 Long Rod 2.4
Machined for Evo oil squirters
COMETIC 87mm Head Gasket
Wiseco HD 9:1 Pistons
Manley Turbo Tuff I Beam Rods
ARP L19 Head Studs
ARP Main Studs
New Oil Pump
Outlander Water Pump
TOMEI Baffling Plate
Fluidampr
Headgames Ported head
Full Ferrera Valvetrain
Curt Brown Intake Manifold
Full Blown 70MM TB
GSC R2 ams
AEM TRU Time Cam Gear
ER MIVEC Cam gear
Gates Timing Belt
Kiggly HLA
MAP Mivec Line
Sparktec Non CDI COP
Old Feb 5, 2014 | 06:06 AM
CoachG's Avatar
No idea on price but it seems like a solid set-up. I'd do some checking on JAM before pulling the trigger though.
Old Feb 5, 2014 | 06:29 AM
tiggeryellow1's Avatar
Veteran: Army
I would say it depends on how many miles is on the build and how much it's been beaten on... or has it been beaten on at all if it's sitting on a stand? If it hasn't been beaten on AT ALL and it's sitting on a stand then there is the matter of who built it? How many of these 2.4L LR's have they built and do they have any sort of street cred? Furthermore if it hasn't been beaten on at all then how does the buyer know if everything was done correctly if the motor has never been run thru hot and cold cycles to see if everything is in order?
I don't think anyone who has ever built an Evo motor or any motor would truly buy a motor and "drop it" into their car without going thru it thoroughly to verify the build. You know... inspecting the gaskets and seals for those stupid leaks that always show up eventually, how do the bearings look, was everything torqued to spec, stuff like that.
Looking at the parts list its a sexy combination of goodness for sure so in the end of the day supply and demand are going to be the factors that ultimately determine the price. Rarely does anyone in here want to pay what anything is worth so either way you're going to take a hit in some capacity.
Jus my .02c
11secEVO7
20
Jan 28, 2017 10:27 AM
OverBoostedEvo
May 16, 2016 06:29 PM
corndog17
West Region
Mar 8, 2016 12:26 PM
PharmEcis
12
Nov 5, 2012 11:23 AM
