Keep OEM exhaust valves? or go with inconel super alloy?
#31
The main considerations are the sodium filled valves ultimately aren't as strong as the solid stemmed counterparts, but that becomes a concern mostly with high rpm and stiff seat pressures. The aftermarket sodium filled valves will flow better than the OEM parts, which again, becomes a factor where such things are at the top of the priority list.
arkangel13 (Sep 1, 2016)
#32
The OEM intake valves you could go bigger on, either +.5 or +1 mm.
FYI, I have SuperTech inconel exhaust valves on my car and the nitrided intake valves.
#33
The SuperTech sodium-filled valves are only available in +1mm, which you wouldn't need unless you're making a boat-load of power.
Now (just for the learning experience), the part I think I am confused is, when they say +1mm or +5mm, that means the valve has +1/+5mm more diameter that can be machined? Or it is just a valve that will open up the ports? to whatever + mm it has?
Still trying to understand that part. Thanks for your advice, very much appreciated for everyone
#35
#36
Ok, I think it is clear now, can't thank you enough for the education!
RallySport Direct
74
Aug 4, 2017 03:31 PM
RallySport Direct
EvoX 'For Sale' External Engine / Power
Nov 18, 2016 11:36 AM
RallySport Direct
EvoX 'For Sale' Engine Internals and Drivetrain
Nov 14, 2016 03:32 PM
Soxman
Sep 25, 2016 01:28 PM
RallySport Direct
Mar 12, 2016 11:41 AM
