Rear diff lock
Old Mar 20, 2014 | 01:08 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
The thing is, the TC fluid issue is the same as the 6 speed issue.
There are people that get away with changing to a different fluid or tracking/abusing their 6 speed and never have an issue. These people invariable end up posting things on the forums like: "This is what I do and I've had no problems" which other people read.
They aren't lying, they are just a vocal minority in this case.
They problem is that when the other thirty (or whatever) people that do have ruined TCs or shattered fourth gears in their 6 speeds don't post, it creates a bias.
People think it's cool to make this change because the majority happens to be silent.
OP: Try some different fluids in the rear diff based on what TRE recommends and if it's not working, then you might have a bigger issue.
Here is some useful info:
https://www.evolutionm.net/forums/ev...ound-here.html
If you are a DIY person, and the diff plates are toast, you might want to replace the clutch discs in the diff yourself. You can do it with simple hand tools.
https://www.evolutionm.net/forums/ev...y-factory.html
SDevol8
Mar 23, 2017 11:26 PM
glen villis
Aug 29, 2016 08:49 PM
AndyCT9W
Apr 27, 2013 07:31 PM
EvosNKitties
Jan 5, 2013 10:13 PM
silverguy
18
Jan 16, 2011 08:23 PM
