Evo 4 CRANKWALKED
Old Mar 23, 2014 | 09:25 AM
2high4u's Avatar
Evo 4 CRANKWALKED
Hey I just bought An Evo 4 off my buddy that had a gross sound in the engine around 2000rpm. I pulled the oil pan and found the crank had been walking a lot, thrust bearing was nearly gone an the crank started wearing into the block. I tossed in mains an rod bearings to buy be sum time while I build an engine.
Has anyone bought any parts from built4g63??? Is there any other parts suppliers out there You'd recommend ? ld like to atleast buy a new short block.
I've also found they changed thrust bearings in the Evo 5 to 3 piece bearing. Can I just change out my 1 piece bearing for a 3 to stop it from walking?
Any feed back would be great thanks!!
Old Mar 23, 2014 | 11:06 AM
2006GSR's Avatar
What clutch do you have?
Also when starting the car after it sits. Do you press the clutch pedal in?
If yes. I would disable the clutch pedal switch so you can start it with out pressing the pedal.
Old Mar 23, 2014 | 11:50 AM
barneyb's Avatar
Probably more important than that initial start with the clutch down is all the hours of wear that could accumulate as you sit a a traffic signal with the car in 1st gear and the clutch pedal down. I trying to train myself to shift to neutral when coming to a stop.
Old Mar 23, 2014 | 11:05 PM
evo7_8u's Avatar
evo 4's are the worst for crank walk.
Old Mar 24, 2014 | 06:50 PM
dubs&boost's Avatar
god am i scared for this too happen. only way to try to help avoid it is the same as said above and keeping the clutch as close to stock as possible.
Old Mar 24, 2014 | 06:53 PM
dubs&boost's Avatar
you can also change to a push style clutch instead of pull
Old Mar 24, 2014 | 07:05 PM
CP9A-Will's Avatar
did some searching to try and find some compatibility in parts between the 5 and 4. this guy seems to have had the same issue:
https://www.evolutionm.net/forums/ev...-opinions.html
Old Mar 24, 2014 | 11:20 PM
Yogi_B's Avatar
No worse than evo1-3s as they share the same thrust bearing design.
A4RON
Apr 26, 2016 02:02 AM
Seancj
Jul 2, 2015 09:07 AM
O0oDC
26
Jun 7, 2014 09:35 AM
9GUY9
327
Dec 17, 2013 09:16 PM
CrashD
May 13, 2010 03:56 PM
