evo9 maf sensor
Old Mar 27, 2014 | 11:15 AM
vitalisevo9's Avatar
evo9 maf sensor
ar evo 8&9 maf sensors compatible to each other? called dealer but could not specify// didnt know if different restriction flow.. thanks
Old Mar 27, 2014 | 11:20 AM
Faisalm's Avatar
Yes they're compatible but I believe you'll need to alter you MAF scaling or else your AFRs will go richer if you install an Evo 8 MAF on to an Evo 9, and it will go leaner if you perform the opposite.
Old Mar 27, 2014 | 11:21 AM
ok thanks
Old Mar 27, 2014 | 11:24 AM
Faisalm's Avatar
No problem.
Old Mar 27, 2014 | 11:29 AM
ok.. seems like there are numbers on maf sensors like 399/281 and so forth.. if its the correct one then i know i wont need to.. but dont know what originally came on it... the dealer states they the same, but hard to believe cause mine MR edition..
Old Mar 27, 2014 | 11:37 AM
Faisalm's Avatar
An evo 8 MAF sensor will fit your evo 9 but you should be more concerned about the MAF scalings because of the alterations that will occur from the swap.
So install it then get a tune and you'll be fine.
Old Mar 27, 2014 | 11:43 AM
k.. just dealers say one thing and others say it work.. i know evo8 runs 62lbs per minute but dont dont evo 9.. guess ill buy it then get it tuned.. didnt want to run it rich/lean then have issues lol..
Old Mar 27, 2014 | 04:36 PM
foxbat's Avatar
Evo 7/8/9 all have the same MAF sensor & the same scaling, you don't need to alter anything.
Old Mar 27, 2014 | 05:48 PM
Faisalm's Avatar
No that is incorrect. A tune is a must if not using the same MAF sensor as the one that came from the factory.
I don't know if this doesn't apply to JDM models, but I'm sure a tune is a must when changing MAF sensors with USDM models.
MAF scalings from both models differ as well which causes the rich / lean issues once the sensor has been replaced.
Old Mar 27, 2014 | 08:37 PM
jrainwater's Avatar
No that IS correct actually. All usdm Evo 8 and 9 models run the 399 MAF. 2003 2004 2005 2006 = 399. Can't speak for jdm though but usdm all have the same ones.
Old Mar 27, 2014 | 09:11 PM
Faisalm's Avatar
So what you're saying is there's no need to change your MAF scalings?
EDIT: I remembered once reading a thread about this and luckily I found it:
https://www.evolutionm.net/forums/ec...djustment.html
Read the second post along with others if you feel like it, and read this thread if you want:
https://www.evolutionm.net/forums/ev...evo-9-maf.html
Notice how there's a trend from the responses?
Old Mar 27, 2014 | 09:23 PM
jrainwater's Avatar
If you're swapping a 399 to another 399 then no it is the same thing and the same scaling and all usdm Evo 8 and 9 models have the 399 Maf. If yours doesn't say 399 then its not a usdm Evo Maf.
Old Mar 27, 2014 | 09:24 PM
Faisalm's Avatar
Please read the threads... Actually I should be saying the same to the OP but too late now. "Search" is your best friend.
Old Mar 27, 2014 | 09:26 PM
jrainwater's Avatar
If you put a cone filter on and a different intake "pipe" thats when it is a good idea to rescale the Maf though. But just changing the sensor itself doesn't require any altering to the Maf scaling raw hertz table.
Old Mar 27, 2014 | 09:36 PM
jrainwater's Avatar
I think you're confusing the Rom scaling with the sensor itself. The Rom scalings on different roms are different because the 8's had smaller turbos and other slight differences thus changing the flow patterns of the sensor. If you swap out the 399 Maf from an Evo 8 to an Evo 9 or visa versa the Rom doesn't change. It's still going to interpret the signal the same way and use that signal for that particular cars set up stock. Different Evo models and hence different roms might scale that sensor differently but the sensor itself doesn't change at all. That guy the said his afr changed when he swapped out mafs either didn't replace it with another 399 or he is swapping between to different 399's that are dirty and used and not giving a proper and equal reading.
